TPMS sensors question
Old Oct 29, 2018 | 07:21 PM
AnalogNow's Avatar
AnalogNow
10th Gear
Default TPMS sensors question
I bought older lexus wheels from someone who used them on his IS350, I have a IS250 F sport. I didn’t get the TPMS senors installed but my car is still giving me my PSI readings for each wheel. Would it be possible that the wheels already had them installed and my car connected to them or is that impossible. I can see the pressure going up and down depending on the temperature outside.
Old Oct 30, 2018 | 07:26 PM
Sasnuke's Avatar
Sasnuke
Unfortunately that would be impossible. For the vehicle to read the sensors the code for each sensor would need to be programmed into the vehicle.
If the vehicle is parked near the wheels you took off, it's possible they could still read the pressures, but it's highly unlikely.
Drive the vehicle for more than 20 minutes consecutively and see what the readings are then.
Old Oct 31, 2018 | 03:41 AM
AnalogNow's Avatar
AnalogNow
10th Gear
My wheels are not close and I drive more then 100km a day. What would show on my dash if my sensors were not reading my tire pressures? I can see the pressure going up and down like my summer tires. Since i got my winter tires installed I have driven over 500km.
Old Oct 31, 2018 | 11:33 AM
NdYAG's Avatar
NdYAG
Who installed the wheels? If it was done in a shop most likely they registered the sensors to your car.
Old Oct 31, 2018 | 02:13 PM
AnalogNow's Avatar
AnalogNow
10th Gear
I got them installed at Costco, I didn’t tell them to do the TPMS because I didn’t know the wheels had them. Would costco even register them without charging me?
Old Oct 31, 2018 | 07:40 PM
kr2015's Avatar
kr2015
Some places will program the wheels without charging you. I know NTB did that for my car. If the sensors weren't registered, you'd see "---" instead of a numerical value. The Lexus dealers like to charge to reprogram but maybe Costco was more customer friendly like the NTB.
Old Oct 31, 2018 | 11:11 PM
Jay89's Avatar
Jay89
Most tire shops include programming in their pricing if they know it needs it
Old Nov 1, 2018 | 07:00 AM
Ajowhan's Avatar
Ajowhan
When possible, usually costco would move the sensor from the older tire to the newer tire
Old Nov 1, 2018 | 07:33 AM
Flash5's Avatar
Flash5
Sensor is attached to the wheel, not the tire. All they usually do is replace the seals on them to make sure no leaks occur.
If you bring new wheels they would transfer them over and still replace the seals etc and it should be included in their price. Usually places ask if your car has TPMS because they will add on the price for TPMS service.
Old Nov 1, 2018 | 09:08 AM
Ajowhan's Avatar
Ajowhan
yes, the wheels is what I mean 😬
Old Nov 1, 2018 | 11:42 AM
zhifan1's Avatar
zhifan1
Probably they transferred your TPMS sensors for you, doesn't require any programming.
Old Nov 3, 2018 | 05:49 PM
AnalogNow's Avatar
AnalogNow
10th Gear
they didn’t swap them i still have one wheel on my winter set missing a stem valve cap. I’m guessing they programmed it without telling me. That’s my best guess.
Old Nov 4, 2018 | 07:35 AM
Answer's Avatar
Answer
They did program them because if they did not, they would not be regognized by the car.
Old Nov 4, 2018 | 04:55 PM
kr2015's Avatar
kr2015
If you have to switch back to your previous wheels for any reason, you'll figure out if they programmed the new sensors for you or cloned the old sensor values
felixsc300
Jun 24, 2021 12:03 PM
iSuxeL
Jul 7, 2009 08:14 PM
thomastan
Mar 19, 2009 01:21 PM
SpaceCadet
Apr 1, 2008 11:42 AM
foshizzle
Wheels, Tires & Brakes Forum
Apr 27, 2007 10:20 AM
