Dealer loaner felt faster, more responsive 2016 vs 2017
He said he has a 2017 IS300. All 2017 IS300s are AWD V6. If he had the 4 cylinder turbo in a 2017, he would have said he had the IS200t. IS200t RWD was not renamed the IS300 RWD until MY 2018.
drives cars
Yeah I hadn't thought about the ECU/transmission learning. I wonder how it manages to keep up with all the different people who drive it. (My guess, not that well)
Pretty much everything I have as a loaner feels a bit more touchy than my IS 300 (AWD, to be specific). Mine's always felt that way - smooth and not too touchy, from day one.
JDR76 (06-26-18)
All the loaners are the lower engine trim variety so all felt sluggish relative to the 350 I have but when I had a G35 coupe, I felt all of the loaner coupes felt faster than mine. I think the adaptive ECU makes this phenomenon common across all makes.
Facelift 3IS is roughly 90 lbs heavier.
Yes confirming my car is AWD. The comparison is pretty much apples to apples except for trim F-sport versus non F-sport. Should be the exact same engine and tranny in both cars.
I wonder if this why when a fresh ECU tune is installed, they recommend certain driving requirements to be adapted during the first 50 miles. In other words working the throttle a bit harder between 3000 and 6000rpm.
Thank you!!
drives cars
FWIW, A) yes, especially the headliner, and B) Sport mode helps with that quite a bit. Especially for me since I don't drive in Sport every day.
OG Member
You can also use Techstream (or an app like "OBD Fusion") to verify that your Knock Correction Learning Factor (KCLV) is at 20+ in order to ensure that your ECU is using its most optimal map. Some engines are "KCLV challenged" and won't provide the optimal fuel/ignition map until you bring the KCLV levels back up.
http://blog.rr-racing.com/news/2017/...on-lexus-ecus/
RKSTRAT
12-12-17 08:59 PM
