18x9.5 +40 squared
Old Feb 14, 2016 | 12:39 AM
Chrispies's Avatar
Chrispies
Default 18x9.5 +40 squared
Does anyone have experience running 18x9.5 +40 w/ 255/35/18 up front on lowered suspension? Any of you wheel fitment gurus think I will run into any problems lowered on Tein Stechs?
Thanks
Old Feb 14, 2016 | 01:44 PM
anthonys2r's Avatar
anthonys2r
Should be fine cruising. High chance of rubbing in the front with those tires when approaching bumps and dips. Rear should be no problem.
Old Feb 14, 2016 | 03:31 PM
Chrispies's Avatar
Chrispies
I'm a bit concerned about going up drive ways. Don't want to pull/crush a fender.
Old Feb 15, 2016 | 02:21 PM
dnasians's Avatar
dnasians
i just test fit my RE30 19x9+40 and I'm REALLY close to that upper control arm. i have a hard time seeing a 18x9.5 fitting in the front without issues
Old Feb 15, 2016 | 05:39 PM
Brokenis's Avatar
Brokenis
R0shiro, a member here is running 18x10 square, think he's running 235's in the front on his track setup
Old Feb 16, 2016 | 07:09 AM
dnasians's Avatar
dnasians
i could see 18x10 with an offset around +30 fit with fender mods, but running 235 tires defeats the purpose of running 10" wide wheels
Old Feb 16, 2016 | 11:55 AM
Brokenis's Avatar
Brokenis
You should check out his thread. I've only seen 2 is's so far with legit track setups. That's his, and evasives 2jz swap. Some tires run wider in 235.
Old Feb 17, 2016 | 02:40 PM
BMS350's Avatar
BMS350
Isn't it that when you go to tracks you need to stretch your front tires so your side walls doesn't flex much. Correct me if I'm wrong.
Old Feb 17, 2016 | 03:57 PM
dnasians's Avatar
dnasians
Tires were not designed to be stretched, especially from a performance standpoint. 235 on a 10" is too much. I've seen drifters run a slight stretch (i.e. a 245 on a 10") in back because it takes away the shoulder of the tire and makes for easier breakaway.
For a track car it sounds straight up dangerous.
Old Feb 17, 2016 | 06:37 PM
iSuxeL's Avatar
iSuxeL
From where I stand you'll need a 5mm spacer up front cause you're probably gonna hit the knuckle or upper control arm
Old Feb 17, 2016 | 07:42 PM
Chrispies's Avatar
Chrispies
Thanks for all the feedback. Guess I'll have to rethink this.
Old Feb 17, 2016 | 07:43 PM
iSuxeL's Avatar
iSuxeL
Also a good tool to use is willtheyfit.com
Old Aug 30, 2022 | 06:48 PM
StealthIS's Avatar
StealthIS
10th Gear
Thanks
Hey did this end up working for you?
skibumm3
Aug 19, 2023 03:46 PM
project350
Mar 27, 2017 01:42 PM
mikez
Feb 12, 2009 04:57 AM
jessels4
18
Jan 28, 2008 12:21 PM
PureZ
Apr 3, 2007 03:57 PM
