Plasti dip window trim question
Old Dec 14, 2015 | 03:43 PM
LeeJonah's Avatar
LeeJonah
Default Plasti dip window trim question
Hey I was wondering for those who dipped their window trim if they completely dipped over the rubber part, masked it off or if it was peelable unmasked?
Old Dec 14, 2015 | 04:28 PM
KYLESTONES's Avatar
KYLESTONES
I completely covered, you can easily peel off the part that gets onto the rubber weatherstripping
Old Dec 14, 2015 | 05:03 PM
LeeJonah's Avatar
LeeJonah
Hey Just to double check, i was asking about the rubber part under the chrome trim. Would it be easy to peel that part off?
Old Dec 14, 2015 | 06:15 PM
KYLESTONES's Avatar
KYLESTONES
It would not be easy, you'd need to razor it perfectly. The crack is too thin the dip won't peel right
Old Dec 21, 2015 | 12:13 PM
dannyl1017's Avatar
dannyl1017
It came off the rubber pretty easy, the only issue i had was the passenger's triangle window at the bottom.
Old Dec 21, 2015 | 12:40 PM
Chrispies's Avatar
Chrispies
Did you dip the front grille trim as well? If so, how many cans of plastidip did you need to cover windows and grille?
Thanks
Old Dec 21, 2015 | 01:06 PM
dannyl1017's Avatar
dannyl1017
You can prolly get away with just one can, I messed up on the emblems a couple times cuz i was rushing so i wasted a couple sprays.
Attached Thumbnails Plasti dip window trim question-lexus2.jpg   Plasti dip window trim question-lexus3.jpg
Old Dec 22, 2015 | 03:59 AM
KYLESTONES's Avatar
KYLESTONES
I used more than just one can for the Windows.. Always better to have extra than to be frugal.. The cans are cheap anyway
Old Aug 28, 2020 | 08:54 AM
cliffhokie's Avatar
cliffhokie
I know I'm digging up a REALLY old thread, but it is the only one that seemed to specifically address this question. Do you plasti dip over the rubber half of the top chrome trim (the bottom 50% that is attached to the chrome), or mask it off and peel away on final wet coat? The response in this thread isn't clear to me. It seems it won't peel away from the chrome since the gap isn't big enough, so do I spray over both (rubber and chrome) and peel away like typical on the window side on the wet coat and one inch gap above the chrome when dry? This would essentially cover the whole thing in a single layer of plasti dip? From most members pictures, it looks like they spray over the entire section. Also, does it break away from the front black triangle piece easily, using the 1 inch gap method?
stephenmat
Mar 10, 2018 06:42 PM
SOCAL909
Jun 4, 2010 09:30 AM
Wald GS
GS - 1st Gen (1993-1997)
May 18, 2006 12:23 AM
