mirror tilt when backing up
Old Mar 29, 2014 | 03:39 PM
akshunj's Avatar
akshunj
Default mirror tilt when backing up
When I first got my IS the mirrors would tilt down in reverse. Somehow this stopped working. I went through all the settings, but I don't see any way to turn this feature on or off. Any ideas? Thx.
Old Mar 29, 2014 | 04:06 PM
ISDAS's Avatar
ISDAS
I had the same problem
I put the car in reverse, then manually selected one side at a time - lowered it to where I wanted it to be, put it back in drive, then reverse again and it worked - just repeat for the other side.
butt yes same issue it just stopped working for no reason - all good now.
Old Mar 29, 2014 | 04:20 PM
kidfsport's Avatar
kidfsport
do you guys have F sports? As I thought I saw it on here somewhere that the mirrors do not tilt on the F sport models,
Old Mar 29, 2014 | 04:21 PM
akshunj's Avatar
akshunj
Nope iS350 lux package
akshunj's Avatar
akshunj
Thanks for the heads up I'll give that a try.
Old Mar 29, 2014 | 04:24 PM
kidfsport's Avatar
kidfsport
ok, because ISDAS avatar has an Fsport in it
Old Mar 29, 2014 | 04:31 PM
PARANOiA2M's Avatar
PARANOiA2M
For the tilt-down mirrors to work, one of your mirrors must be 'selected'. For example, when you are adjusting your mirrors, you choose the L or the R button and a little light turns on. If you push it again, it turns off. One of these buttons must be selected as 'on' for the tilt-down mirrors to work. I usually leave my L on.
Old Mar 29, 2014 | 05:02 PM
ISDAS's Avatar
ISDAS
PARANOiA2M, mine still didnt work with this.. the mirrors (when I selected reverse) actually moved up a mm or so, almost like they were 'trying' to work but didnt - same with L and R - only thing that worked was me manually setting where I wanted it to dip, drive, reverse - then all good.
and I have an F Sport - Australian spec though with dipping mirrors.
Old Mar 29, 2014 | 05:14 PM
kidfsport's Avatar
kidfsport
gotcha, and stupid Lexus...that should be a standard feature when the car is equipped with things like rear camera and bsm especially when they are not going to offer a package to have it,smdh
Old Mar 29, 2014 | 05:22 PM
ISDAS's Avatar
ISDAS
pretty surprised its not a feature on the f sport in the US.. it should be on every model it will save your rims!
i HATED when it stopped working as I have never curbed a wheel in my life and this feature really makes sure I keep it that way.
I mean we do pay a lot more over here but
mark lev
bsm
heated/ventilated
seat memory
dipping mirrors
etc is standard
you only pay more for the EP1 (moon roof only) or EP2 pack (moon roof, pcs, lane departure, radar cruise)
but hey we dont get fogs either..
Old Mar 29, 2014 | 06:49 PM
PARANOiA2M's Avatar
PARANOiA2M
I forgot to mention that your tilt down mirrors are actually a setting for while you are in reverse. Once the car is in reverse, as long as your L or R are selected, you have to actually set the mirrors yourself--once you do that, the next time you shift into reverse, it will return to the last position you set it to when you were in reverse.
Old Mar 29, 2014 | 07:09 PM
ISDAS's Avatar
ISDAS
when I picked my car up this was already done for me (dealer demo'd) the day after they stopped working which was strange.. but no issues since I did the above ^
Old Mar 29, 2014 | 07:14 PM
corradoMR2's Avatar
corradoMR2
The pursuit of F
Reflecting what PARANOiA2M has stated, as with every other Lexus with Memory Seats, selecting the mirror switch to "L" will allow both sideview mirrors to tilt down. If still no go, there could be a problem for you to have the dealer check it out. Good luck.
Old Mar 29, 2014 | 09:21 PM
dojoman's Avatar
dojoman
If the mirrors tilt down you cannot see what's on the side of the car when backing up. I know there are rear view camera and mirrors but normally when I'm backing I can catch pedestrians and bicyclists in the side mirrors first.
Old Mar 30, 2014 | 11:16 AM
akshunj's Avatar
akshunj
Thanks this turned out to be the cause of why it stopped working.
Ken167
Mar 13, 2024 08:23 AM
Wisconsin1
Mar 27, 2019 06:31 AM
kchemist
Apr 2, 2016 06:38 AM
smokyis350
Apr 23, 2013 04:37 PM
xssax
Nov 15, 2010 09:29 PM
