is350 engine noise
Old Jan 3, 2024 | 12:21 PM
frank357's Avatar
frank357
Default is350 engine noise
Hi there,
My engine do an up and down noise, any idea?
Old Jan 3, 2024 | 12:25 PM
KennyFSU's Avatar
KennyFSU
Up and down noise... You mean the noise gets louder and quieter?
Any CEL/codes? Does turning AC on/off make any difference?
Old Jan 3, 2024 | 12:32 PM
frank357's Avatar
frank357
Yep exactly
The noise get louder with higher RPM, but not faster. After 2000 rpm, its hard to hear it
No CEL code
Old Jan 3, 2024 | 12:41 PM
KennyFSU's Avatar
KennyFSU
It almost sounds like a clutch pulley or bearing is bad but hard to tell unless I hear it in person.
Old Jan 18, 2024 | 04:54 PM
frank357's Avatar
frank357
I found a video with this exact same sound and its about the alternator. Me, my friend and the mechanic guy tell the same, its probably the alternator. I put a metal bar on it to listen and it seem to come from here
is350 2018 seem to have 2 alternator versions, one with 6 grooves(angle bracket) and one with 7 grooves(straight bracket). Mine seem to use the 6 grooves one. But how the **** the 7 grooves can cost 350$ and the 6 one 750$?!! The only difference is the grooves and the bracket. The power output is exactly the same, 150a
What I can do to reduce the cost?
Old Jan 18, 2024 | 05:25 PM
frank357's Avatar
frank357
I finally found one on rockauto for 360$ CA shipped! Refurbished from BBB Industries. Someone here have experience with this brand?
Old Jan 19, 2024 | 10:56 AM
cerbois's Avatar
cerbois
maybe take the belt off and see if they pull has a lot of play.
laurentj23
Jun 12, 2022 10:18 AM
theoryguy3
Aug 19, 2020 12:54 PM
skydash
May 16, 2017 09:06 PM
Mr. T
Mar 11, 2011 04:48 AM
aboss3
Apr 24, 2009 08:54 AM
