Steering Control Module
Old Sep 24, 2022 | 01:00 PM
B777Pilot's Avatar
B777Pilot
Default Steering Control Module
I am having the dreaded PS warning light and stiff steering on my 2010 IS 250. Battery and alternator is all in good condition, I will be changing the power steering module located under the battery.
Question do I need to get the new computer (Junk Yard) one calibrated with a OBDI Computer after I install it or is it plug and play.
Thanks......
Old Sep 25, 2022 | 06:17 AM
Cali2is's Avatar
Cali2is
Should be plug and play…. Never hurts to have it recalibrated to your car at some point though.
Old Sep 25, 2022 | 03:01 PM
naikey's Avatar
naikey
8th Gear
Thanks......
Hi ,
Mine is same problem and am stuck ,did change module from same part number did not work hope you are lucky. let us have update once you have sorted.
thanks
Old Sep 25, 2022 | 07:55 PM
2013FSport's Avatar
2013FSport
Thanks......
Originally Posted by naikey
Hi ,
thanks
The most common issue during this repair is battery polarity reversal, which knocks out the fuse.
By the battery is series of fuseable links under a clear cover. Look for the 80 Amp one near the 140A connection. Chances are, its blown. Look for an opening in the center of the Z.
Either of you notice if the stereo works?
GL...
Old Sep 26, 2022 | 09:09 AM
naikey's Avatar
naikey
8th Gear
GL...
hi,
sorry not trying to hijack this discussion, in mine everything works and even the ps module get power through fusible link , i suspect another fuse after the module sending power to the power steering rack and back so it operates , i maybe wrong but in mine power does not go to rack,. i dont know out of my knowledge here.
more help and ideas please
sorry
Old Sep 26, 2022 | 09:10 AM
evrynite's Avatar
evrynite
I had to do the same on my 07 IS350. Had to also replace the rack and pinion because it seized up @ 150k miles.
The salvage PS ECU def needs to be recalibrated using Techstream. I mean you can take your chances and run it without going through the procedure, but your car will most likely steer and handle strangely if you do not.
Old Nov 8, 2022 | 06:46 AM
B777Pilot's Avatar
B777Pilot
Took the car to my local Lexus Dealer, all I needed was a new alternator and replace the 6 month old battery that already had a battery cel die. Lesson learned is that the
electric power steering in this cars are very sensitive to power supply, if there are any fluctuations in voltage the rack will shut down.
Old Nov 10, 2022 | 07:01 AM
Gville350's Avatar
Gville350
Sucks to hear that was the issue, but it's now resolved AND it could help someone down the road with diagnosing the very same issue.
AlexRB
Oct 5, 2023 02:50 PM
Mythreecar
Dec 22, 2020 12:14 AM
miket000
Jan 14, 2020 05:29 AM
Lexus350AJ
Maintenance
May 8, 2017 06:01 AM
nnu8unn
Feb 12, 2011 11:18 AM
