Oil catch can
Old Jan 19, 2017 | 05:38 AM
QuazeFaxi's Avatar
QuazeFaxi
Default Oil catch can
Starting to experience rough idle when i start the car at first. I know about the carbon build up issue and I was looking into getting a oil catch can. Any recommendations as to which to get? maybe one that fits the 2006 IS250 AWD the best.
Thanks in advance for the help.
Old Jan 19, 2017 | 11:50 AM
Trolling55's Avatar
Trolling55
isn't all catch can universal? just need to find a place to mount it?
Old Jan 19, 2017 | 04:18 PM
Mrfix's Avatar
Mrfix
Search ebay. They typically have a few to offer. It may be a little late for the Catch Can but you might want to start with trying to clean the engine out. I would check youtube for decarbonization of an engine with water. Start running fuel cleaner (Berrymans/Seafoam) through each tank.
Old Jan 20, 2017 | 02:00 PM
sktn77a's Avatar
sktn77a
If it's already idling rough, then its too late. Need to fix it and then add the catch can.
Old Jan 21, 2017 | 08:26 AM
trippy's Avatar
trippy
i dont think its to late ? had my misfire recall in 2013 felt it in 2016 and installed an catch can and went away.
Old Jan 23, 2017 | 11:28 PM
chriso5573's Avatar
chriso5573
Here is a DIY I wrote a while back for RR Racing's catch can originally for the IS F. It's the biggest/best one in my opinion, works amazing, and holds a lot of oil so I don't have to monitor it. Hope this helps.
https://www.clublexus.com/forums/is-...rator-diy.html
Old Jan 23, 2017 | 11:47 PM
APynckel's Avatar
APynckel
You need 2 catch cans, fyi. You need to intercept BOTH PCV hoses from the valve covers to the intake tract, SEPARATELY. The one on the intake filter side of the TB needs one, and the one on the intake manifold side of the TB needs one. Do not get one for both.
Old Jan 24, 2017 | 04:10 PM
APynckel's Avatar
APynckel
Also, you can make one of these yourself easily with a norgren filter for an air compressor...
https://www.imi-precision.com/us/en/...ansparent-bowl
Add in some 1/4 NPT fittings and some 3/8 hose from autozone and you have a catch can for less than 1/2 the cost. Only thing you have to do is fab up a bracket.
daan3757
Dec 31, 2022 12:06 AM
krisk1
CT 200h Model (2011-2017)
Oct 12, 2016 03:10 AM
jvah1980
Aug 13, 2016 08:03 AM
FrankWhite
Jan 8, 2008 09:04 PM
mikewpu04
May 9, 2006 02:04 PM
