Tensioner pulley whole assemble AWD different to RWD ?
Old 09-11-16, 03:06 PM
The350Girl
The350Girl's Avatar
Default Tensioner pulley whole assemble AWD different to RWD ?
My sister 2009 IS250 AWD got chirping noise lately and it's annoying her, she has replaced waterpump driving belt and idler pulley the Chirping was still there, so my BF said must be the Tensioner Pulley, we ordered a used Tensioner Pulley whole assembly used on Ebay "RWD" brought to the shop yesterday and the mechanic said this RWD will not fit AWD, her car is 09 IS250 AWD ??? so RWD tensioner pulley will not fix the AWD ?
The mechanic told her the only thing he could do for her is replace just the Pulley not the Arm, after that the noise seems gone but this morning she just called me and said the Chirping still there even with the new Pulley ? Can anyone please tell me what could it be ? everything new and the Chirping still there ?
Old 09-11-16, 03:36 PM
umvmyrx7
umvmyrx7's Avatar
i had the same issue, the culprit was the clutch on the alternator. pop the plastic cap off the alternator pulley and spray with wd 40 and see if it continues. i was able to prolong not changing the alternator or the clutch.
Old 09-11-16, 07:55 PM
The350Girl
The350Girl's Avatar
Thanks for the great tip, will do that.
"So no one has the answer ? she said just now she also feel the accelerate is harder than before, it feels like the car don't want to go when she press the gas pedal"
Old 09-12-16, 11:34 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The tensioner is indeed different between RWD and AWD. You will need to make sure you get the correct one for the car.
Jeff
Old 09-12-16, 04:35 PM
The350Girl
The350Girl's Avatar
Jeff
Awww, Ebay matching part system shown it fits .....i should have asked here before ordering.
Old 09-12-16, 04:39 PM
The350Girl
The350Girl's Avatar
Hi there, thanks for your input, i'm 350girl's BF, The 09 is250 Nancy bought was used, i couldn't find the plastic cap from the Alternator, is there video or picture that you can post for me, thanks in advance.
Old 09-12-16, 05:02 PM
Gville350
Gville350's Avatar
^The cap is plastic and simply covers over the nut/bolt holding the ALT pulley onto the ALT. Use a pick or a small flat screwdriver to pry it off to gain access to where you might want to try some silicon lube spray.
Old 09-12-16, 07:33 PM
liqB
liqB's Avatar
Old 09-14-16, 03:11 PM
The350Girl
The350Girl's Avatar
Originally Posted by liqB
Wow million thanks, awesome you guys are the best
jimjaix
Performance
10-09-18 08:04 PM
patjza80
04-28-18 02:24 PM
dis250
10-13-09 05:28 PM
gilly
02-25-09 12:06 AM
vader11
11-06-06 02:37 PM
Quick Reply: Tensioner pulley whole assemble AWD different to RWD ?
