I recently ordered 2 LED 9005 Bulbs for my IS in order to match the DRL's to my 6000K HID low beams. However, when I installed the DRLs only come on when I turn on the high beam function.
I searched all over the forums and haven't found a solution.
Do I need a decoder for this conversion to work? I have the same issue with the fogs.
Your DRL bulbs work by outputting a lower voltage to the bulbs and then on high beam the voltage increases. Incadescent bulbs can operate at lower voltage, at a reduced output. Where as LEDs have a minimum threshold voltage to illuminate.
The decoder module will bump up the voltage to work with the LED.
The decoders that came with the bulbs I bought weren't good enough and I had a slight flicker. After contacting the company (ebay seller), they sent me replacements that worked great! No problems since.
For installation of the decoder, is it just plug and play? I just ordered one off of amazon to try out on my fogs. I really want to get rid of these yellow halogen lights and make them look like yours!
Did you ever have your DRL function off? It's sound like you disable DRL.
It's support to flickering if you don't have decoder but not completely off unless you disable it. Double check it!!!
Imma try to get mine disabled when i get the recalls done. Hate them lights on during the day, ive been lazy but need to do it
I never disabled the DRL. Is there anyway to check? I heard you have to take it into the dealer to have them turned off.
