So I picked up a set of 19" genesis coupe track wheels, from what I've read through the forums that you don't need much to run on them, just "plug and play".
However, I'm just curious would I be able to use stock lug nuts from my OEM 18"s or would I have to use the OEM lug nuts from Hyundai or aftermarket lug nuts?
You can buy any conical type nuts but DO NOT use oem lexus ones since they're mag type.
All aftermarket for the most part are conical. Buy some cheap gorillas and call it a day.
Don't buy the aluminum colored lugs because they fade like crazy and if they're over-torqued they deform.
We'll you dont necessarily need hub rings. Though you might get a shimmy in the wheels without them.
They're cheap enough to where there is no reason not to get them.
