Check System light ( HELP )
okay so i searched everywhere and done all most everything and i cant get this to turn off. i reset the ecu (plugged out batter let it sit for 3 hours plug back in ) still on. I check tire pressure all fine at the manual specifications. and dint even mess with the switches under steering wheel came on after i bought the car i have a 3 year warranty but a 100 $ deductible and being a college student that's a lot right now any way i can turn this off its bugging the crap out of me.. please help me =[
car is a 06 is250 w 64k
auto zone said they cant scan a check system light with a obd2 and i had advance auto parts try and wouldnt read any codes
My bad I thought it was a cel. Is there any other symbol with it? If so look at your owner manual it will tell you. Maybe your tire sensor reading low pressure?
Sounds like one of your TPMS might be dead or broken. The system has to sense 4 TPMS or it will give you a Check System error. Have the dealer or tire shop check to see if all 4 TPMS are working.
"Check system" is a tire pressure sensor problem. The first thing I would check is to make sure that you didn't accidentally set the system to use the alternate set of sensors. (The menu is accessed from the controls that look like < O > to the left of the steering wheel.) If that setting is okay, I'd go with MrBBQ's advice and get the sensors themselves checked.
Assuming it's on the correct set of sensors you can also reset what the "correct" pressure is using the <o> switch too... directions in the owners manual. That'd be the only other "free" thing to try really.
airceo13
Dec 8, 2011 02:32 AM
