HID issue...?
Old Aug 22, 2011 | 09:13 PM
mick5410's Avatar
mick5410
Default HID issue...?
I have a 2010 Lexus is350. About four months ago I have recplaced my HID bulb to a brighter 6000K with aftermarket bulbs, tonight for the first time my driver's side HID will go off and I will have to turn my lights off and then back on in order for it to come on and after I drove it another 10 minutes it would go off again....anyone have experience this issue?
Old Aug 22, 2011 | 09:17 PM
kumquatism's Avatar
kumquatism
CL Folding 100,000
Sounds like a bad ballast, but can't rule out the bulbs either. Switch the driver and passenger sides, and observe what happens. If it's still the driver side going out, then the ballast is most likely bad, if it changed to passenger side, then it's the bulb obviously.
Sounds like you're still under warranty anyhow. If it's indeed the ballast, then put back your stock bulbs and bring it to the dealership.
Old Aug 22, 2011 | 09:19 PM
mick5410's Avatar
mick5410
Thanks a lot
Old Aug 23, 2011 | 09:47 AM
RBL250's Avatar
RBL250
cant believe somebody else has this problem too...i took the car to lexus of queens because after i bought the car i noticed some loose parts inside the headlight...the replaced both actual headlamps then all of a sudden my driver side started turning off by itself ...i would have to reset it all the time to make sure its on....then i took it to lexus of Manhattan and then said they found loose wiring on the bulb....they fixed the wires and swapped bulbs from left to right....they said it SHOULD be okay but if its not....the light will go off on the passenger side now....now its going OFF ON THE PASSENGER SIDE!!! LMAO i just got off the phone with lex of Manhattan...they are taking my car in tomorrow to replace it...even tho i have the platinum warranty...u still get crap service.
Old Aug 23, 2011 | 08:34 PM
mick5410's Avatar
mick5410
Keep me update on the result. I am going to swap my bulbs tonight and see what happens.
Old Aug 23, 2011 | 08:40 PM
langjaykev's Avatar
langjaykev
Make sure you connected the bulb properly. Happened to me too. Flickers then turns off. Then id had have to turn it on again but itll flicker in couple of minutes and turn off.
Old Aug 24, 2011 | 04:53 AM
RBL250's Avatar
RBL250
so....i just dropped it off at lexus of manhattan and they said they will just replace the bulb on the right side since it seems to be faulty....i told him whenever i try to leave it on expecting it to turn off...it stays on...wen im on the highway not even thinking about it...it turns off....the light has a mind of its own.....plus he is fixing the passenger side puddle lamp...the bulb seems to be loose...
i think u should swap bulbs only from left to right and see if the problem switches sides...if it does then its the bulb...if its still the driver side...u know its the ballast
Old Aug 29, 2011 | 09:39 AM
mick5410's Avatar
mick5410
Thanks for the update. I already flip side seems to do ok right now. It may have to do with the connection. Still keep an eye on it. Good luck with yours.
patstar
Oct 3, 2013 11:42 AM
sayWho
Lighting
Jan 6, 2012 09:07 PM
cjhurtado2
Aug 29, 2010 01:12 AM
2slow
Lighting
Mar 2, 2009 12:03 AM
96sc3
Lighting
Dec 6, 2004 12:04 AM
