Down shifting problem
Old Oct 7, 2010 | 03:29 PM
flektone's Avatar
flektone
Default Down shifting problem
When slowing down between 40 and 50mph my car sometimes hesitates to down shift properly. The rpms shoot up to 3 and the cars pulls back. Doesnt happen all the time but something I notice now and then. I bought the car used with 27k miles. Is this a symptom of a transmission slipping? Should I be concerned of this getting worse? I dont beat on the car and drive it smooth.
Old Oct 7, 2010 | 06:19 PM
chikoo's Avatar
chikoo
Did u get the recall done?
Old Oct 8, 2010 | 05:48 AM
flektone's Avatar
flektone
which recall? If you are talking about the valve spring it doesnt apply to the AWD
Old Oct 8, 2010 | 06:10 AM
MiiK350's Avatar
MiiK350
My guess is you have have it in ect power on when this happens. If thats the case, its normal.
Old Oct 8, 2010 | 06:11 AM
sigteacher's Avatar
sigteacher
I have noticed this too, but only when the ECT power is enabled.
Old Oct 8, 2010 | 06:15 AM
flektone's Avatar
flektone
no I dont use the ECT power mode at all.
Old Oct 8, 2010 | 08:23 AM
chikoo's Avatar
chikoo
Gas pedal recall
Old Oct 8, 2010 | 09:38 AM
DaSyce's Avatar
DaSyce
This happened to me once on my 350, I was driving aggressively at the time. I let off the gas as I approached a slight downhill descend. The car shifted from 6th gear to 5th. After the initial pull back from the gear change, the car started gaining speed as I was going downhill. (~75mph)
I figured the ECU was adapting to my driving mood, the car felt incredibily aggressive.
Nothing was disabled, and the car was not in power mode.
Old Oct 9, 2010 | 06:20 AM
flektone's Avatar
flektone
my bad I guess the ECT button is on. I never mess with it. I dont have it pushed up which is PWR mode. So I guess ECT is on
Old Oct 9, 2010 | 06:42 AM
mikez's Avatar
mikez
The car's auto down shifting from 5-4-3 sucks if your driving habit is a bit on the aggressive side (moderate acceleration, sudden braking etc).
If I am going about 55 - 60 and I am braking down to about 30 - 40 for a jug handle turn off the road, I usually hit the brakes so the car drops down to 40 fast, downshift from 5 to 4 myself while blipping the throttle, then keep braking down to 30 and the car will be silky smooth since the transmission tends to hang in neutral for a second when you are braking.
Old Oct 9, 2010 | 07:39 AM
flektone's Avatar
flektone
I bought the car used. Im wonderin if I reset the ECU if it willl make any difference. Im sure the person before me beat the hell out of it cuz it was a lease, lol. Im more of a mellow driver
Old Oct 9, 2010 | 09:51 AM
chikoo's Avatar
chikoo
I checked...does the same for me...I drive ECT Power mode all the time.
I think it is the computer blipping the throttle for the downshift.
poplatino4
GS - 1st Gen (1993-1997)
Dec 18, 2010 09:11 PM
mr29rose
Aug 13, 2009 01:10 PM
sammy5001
Apr 14, 2008 09:37 AM
you89
Jul 7, 2006 09:29 PM
purebliss
Performance
Nov 9, 2002 08:19 PM
