IS 350 with jerky acceleration (from stop)
Old Apr 13, 2008 | 06:34 PM
sammy5001's Avatar
sammy5001
Default IS 350 with jerky acceleration (from stop)
Premise: I have a new 2008 IS 350 with 300 miles on it so far.
Problem: Thus far I find that the acceleration (from a stop) seems very jerky. I've tried applying various degrees of force on the pedal and it doesn't help much. In fact, the acceleration is the smoothest if I just floor the pedal. When I hit the pedal softly, it seems as if though the transmission shifts from 1 to 2 then to 3 too quickly and prematurely. If I turn on Power Mode, then it holds the gear longer and the acceleration is much smoother. But I don't want to keep it in Power Mode because I want to save gas. Anyone else having this this problem? With the default (non-Power and non-Snow) mode I'd expect the ride to be the smoothest--clearly that's not the case.
Old Apr 13, 2008 | 06:39 PM
stvn's Avatar
stvn
i thought the upshifts were not as fluid as they could be at first too, but after riding for ~2500 miles now the shifts seem a lot smoother like the transmission evolved..? also you will eventually learn when the car shifts gears and you can vary your pressure accordingly
Old Apr 13, 2008 | 06:49 PM
HKS350's Avatar
HKS350
The ECU is in "learn mode" right now. Give it time and drive the car normal. If you are off and on the gas trying to get the car to stop the jerky feeling the ECU will learn this driving style.
Old Apr 13, 2008 | 08:00 PM
iKenn's Avatar
iKenn
Just call me "Sprinkes"
is it in ECT PWR mode?
Old Apr 13, 2008 | 08:10 PM
llamaboiz's Avatar
llamaboiz
i run in snow mode
Old Apr 13, 2008 | 08:12 PM
iKenn's Avatar
iKenn
oh i should have read the whole post.
Old Apr 13, 2008 | 08:28 PM
Zinda's Avatar
Zinda
I am interested in this issue because I have different people driving my car. So does the ECU adjust for them as well?
Old Apr 13, 2008 | 09:41 PM
eric_r_ho's Avatar
eric_r_ho
Bring it back to the dealer and have them re-adapt the transmission..maybe it wasn't done right from factory. Let the transmission learn the values correctly. It happens..
Old Apr 13, 2008 | 09:52 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
The shifting should smooth up in time... my 250 shifted erratically at first also, and now i just over 1200 miles on it, and it seems to be a night and day difference. If you are really concerned, you can bring it to the dealer and have them reset the learned values, and it can start from scratch again. No such thing at "re-adapt".. I think you'll be ok though.
Old Apr 13, 2008 | 10:56 PM
Rividsoul's Avatar
Rividsoul
Hopefully this is not a dumb question, but does the MT's ECU have a learn mode as well?
Old Apr 13, 2008 | 11:02 PM
eric_r_ho's Avatar
eric_r_ho
I doubt it..if anything it just has a fuel trim compensation for the ever-changing/deteriorating condition of the motor..
Old Apr 14, 2008 | 09:37 AM
crzyis's Avatar
crzyis
****DO THIS AT YOUR OWN RISK!****
Just pull your EFI and ECT-S fuse in the box wait about 2 min put them back in and the tranny will be rest in learning mode. The first time you go to start the car it will not start but hit it again and it should come up just fine.
Jmlee44
Jul 6, 2017 05:04 PM
flektone
Oct 9, 2010 09:51 AM
mr29rose
Aug 13, 2009 01:10 PM
kilowatt
30
Oct 15, 2006 04:54 PM
Isaak
Sep 23, 2001 06:07 PM
