Old Dec 16, 2014, 11:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
LED Lighting Replacement Guide (w/Pics)
Old Dec 20, 2011 | 05:06 AM
  #481
Joeb427's Avatar
Joeb427
Originally Posted by brociouz
The only problem I had with radially firing LEDs in the front dome is that it would cause shadows and weird reflections to show up on the dome light lens. Did you have that problem at all? The single, downward firing LED looked cleaner to me.
Brian,I didn't remember anything unusual earlier and just checked now.
You can see where the LED firing down but really doesn't look much different than if a bulb was there instead of the LED except for a white light vs yellow blah.
I think that single LED may cause more shadowing.you would have one LED firing and the brightness would be only there and not in the whole lens.
I didn't want bright,just white and the light output seems of that of the stock bulbs without the yellow.If you want bright,these won't work for you.
I have the map lights for more light when needed.
Old Dec 21, 2011 | 09:32 PM
  #482
thebossac's Avatar
thebossac
i am planning to get the cree led back up light as well, when i search on ebay, i came across this one:
http://www.ebay.com/itm/130617595497...84.m1555.l2649
same price, same item but US seller, did anyone try it? they tested it on a Lexus, looks very nice
Originally Posted by Kasim
Ok,
while ago i got cheap 2x 42 LED SMD T10 168 194 Wedge Turn Signal Light White $7 reverse bulbs from Fleabay (couldn't pay $50 for v-leds)
Here's original post
as brociouz said, you don't know how bright they are until you compare.
As usual he was right.
Looking at the posts about CREED backup light ($40) from JLC i start searching around and again i've found similar "creed" on fleabay for $28 not as fancy box as from Jlc
Here's my pics, on the left "new" ones.
Bulbs
Will c how long they going to Last
Old Dec 23, 2011 | 01:18 AM
  #483
Sango's Avatar
Sango
Back in Canada. Here is JLC Lights in the dark with no flash.
The trunk light, had difficulties getting it perfect because its over exposed because of the LED. Attemping to make the shutter speed faster to counter it does not work because the area the LED lights up becomes too dark. The pics does give an idea what how bright it lights up the area.
http://img444.imageshack.us/img444/7073/img1455o.jpg
http://img85.imageshack.us/img85/2490/img1456t.jpg
http://img819.imageshack.us/img819/6656/img1473zo.jpg
http://img715.imageshack.us/img715/9561/img1482z.jpg
http://img827.imageshack.us/img827/7955/img1483k.jpg
Old Dec 23, 2011 | 08:08 PM
  #484
Sango's Avatar
Sango
Added pics.
http://img545.imageshack.us/img545/5841/img1489t.jpg
http://img502.imageshack.us/img502/3539/img1490sg.jpg
http://img828.imageshack.us/img828/7616/img1491b.jpg
http://img828.imageshack.us/img828/3324/img1494u.jpg
http://img20.imageshack.us/img20/9071/img1495b.jpg
http://img808.imageshack.us/img808/718/img1497s.jpg
http://img443.imageshack.us/img443/393/img1498hns.jpg
http://img687.imageshack.us/img687/2708/img1500mi.jpg
Old Dec 24, 2011 | 10:07 PM
  #485
Sango's Avatar
Sango
Got the JLC 13-SMD T10 installed for reverse lights. Taken at different exposure rates since its so bright - gives an idea how bright they are.
Old Dec 31, 2011 | 01:53 AM
  #486
CLIS250's Avatar
CLIS250
this may have been asked before, searched through this thread but only saw 1 or 2 questions relating to my question but not really direct on. for a 09 is, we have turn signals on the back of our mirrors. when i want to install LED's for the puddle lights, do I pop the mirror off the same way as people are doing for the 06-08? like pop the mirror out and take out the 4 screws and pry the back housing out? or is there a different way since there is a turn signal on the back housing of the mirror? thanks! probably going to buy the JLC ones since they seem to be the only ones that fit!
Old Dec 31, 2011 | 02:37 AM
  #487
Sango's Avatar
Sango
Yep, basically teh same.
Just to note, the LED turn signals on the mirrior is intergrated, therefore not replcable unless the unit itself is replaced.
Old Dec 31, 2011 | 11:50 AM
  #488
brociouz's Avatar
brociouz
From what I remember, it's pretty much the exact same procedure. Be careful with that mirror though, they can and do break if you pull too hard.
Old Jan 1, 2012 | 03:14 AM
  #489
CLIS250's Avatar
CLIS250
after viewing all the pages of the thread, is it still the easiest way to install those puddle lights? by removing the mirror turned all the way up and pull? or is there a new more efficient way? Thanks!
Old Jan 1, 2012 | 06:18 AM
  #490
Joeb427's Avatar
Joeb427
If you have a helper you can have the helper pull the mirror down/up and a longish thin Phillips head screwdriver to get to the screws without popping the mirror glass pieces off.
That's the way I did it.
Old Feb 1, 2012 | 08:11 PM
  #491
TrancEpimp's Avatar
TrancEpimp
www.vleds.com
Only 4 more hours left to take advantage of our Facebook Fan codes!
Here they are again:
FBFAN = 20% off all items (no min order amount) 2 uses per buyer.
FBFAN200 = 25% off all items ($200 min order amount) 2 uses per buyer.
Old Feb 8, 2012 | 06:28 AM
  #492
TUNG's Avatar
TUNG
Default VLEDs Puddle Light
In brociouz thread about LED Lighting Replacement Guide, he was showing the 5k VLEDs for the puddle. I planned on buying it but when I was looking at the bottom under Detail Tab, it says " Will not fit Lexus IS puddle light application." ? What is there that I could do and how did you guys get it to work when it says it won't fit the IS puddle light. Sorry for all these questions, I just wanted to get my light mods done.
VLEDs 5K Bulb (brociouz mention)
http://www.v-leds.com/Interior-LED-B...25900-1-2.html
Brociouz Lighting Replacement Guide
https://www.clublexus.com/forums/is-...de-w-pics.html
Thank you everyone, and Brociouz for the GUIDE!
Old Feb 8, 2012 | 06:58 AM
  #493
Sango's Avatar
Sango
That's because the new style changed the deisgn so it is too long such that it will not physically fit unless you modify the housing.
In that case, rather go with JLC's 5-SMD where it would fit just fine.
Old Feb 8, 2012 | 07:24 AM
  #494
brociouz's Avatar
brociouz
I think you missed the following from my first post:
UPDATE: The LED bulbs I recommend for the puddle lights have been redesigned and no longer fit perfectly. Read this thread for more info: https://www.clublexus.com/forums/is-s...le-lights.html. With some minor dremeling it still works fine.
The link above contains the information you're looking for. You'd need to do some slight modifying, but it's worth it if you want the brightest puddles possible.
Old Feb 24, 2012 | 05:31 PM
  #495
langjaykev's Avatar
langjaykev
http://www.v-leds.com/Exterior-LED/P...26829-1-2.html
Do these fit on 11's tails ?
I tried putting these on my car, but it seems like its bigger than the OEM bulb o.o both is size 921, so im confused!
