HID problem
Old Jun 6, 2010 | 06:21 PM
Willdb15's Avatar
Willdb15
Default HID problem
OK so about a month ago i took my car to a shop and they opened and blacked out the housings in my headlights now there is moisture in my right headlight and my oem lexus hid's on that side only work sometimes. What can i do to fix this?
Old Jun 6, 2010 | 06:25 PM
alan003's Avatar
alan003
put some silica gel in there to get rid of the moisture. see if that helps
Old Jun 6, 2010 | 06:27 PM
Willdb15's Avatar
Willdb15
where do i put that and where can i get it do i just put it inside the headlight by removing one of the lights and then reseal?
Old Jun 6, 2010 | 06:33 PM
nmpeter's Avatar
nmpeter
If you take off the grommet for a few days and leave it sitting in your garage the moisture SHOULD get out. It happened to my fogs after being submerged once.
Old Jun 6, 2010 | 06:37 PM
Willdb15's Avatar
Willdb15
ok do you know it the silica gel works? Will it be bad if i put it in my headlights and fogs with the heat generated by the lights. Also what grommet did u take off?
Old Jun 7, 2010 | 01:44 PM
Willdb15's Avatar
Willdb15
ok so i was driving last night i got home and the right headlight was working!! but sadly this morning it was not working anymore this means the ballast isnt blown but still something is wrong any suggestions?
Old Jun 7, 2010 | 02:19 PM
new.era.13's Avatar
new.era.13
probably the bulb. try switching them and see if that works.
Old Jun 7, 2010 | 02:29 PM
Willdb15's Avatar
Willdb15
can you get the bulbs out while on the car can i see a diy?
Merkelbach
Aug 15, 2017 05:44 PM
IXI187IXI
General Classifieds
Sep 20, 2010 12:52 PM
ghd8989
Jul 23, 2007 11:47 AM
bishop977
Lighting
Apr 25, 2004 06:50 PM
