Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
- Lexus IS GS: How to Replace Spark Plugs
Step by step instructions for do-it-yourself repairs
DIY: IS350 Spark Plug Service
when you use antiseize or oil on the thread you have to downrate the torque setting on your wrench a little or else it will be high, since the anti seize and oil assists in torqueing down
Thanks for putting this thread together as I found it very useful indeed. That being said, I changed my plugs earlier today and noticed that my back 2 plugs on the passenger side had some oil on the threads and were a little darker than all of the others. I have never had any issues with my car but this did concern me. What do you guys think about this?
Also I have the dreaded VSC light on after performing this work. I have seen various posts where people mention that a wire was loose or that they had to reset the battery. I have already tried the battery and have triple checks all of my connectors. Does anyone else have any ideas on what this could be? It's pretty frustrating. Thanks
I have the same problem as Soap. After I changed out the spark plugs and replaced everything the engine, TRAC, and VSC light came on. The car runs perfectly no misfires and no gas in the oil. I haven't tried restarting the battery like Soap did, yet. Could getting dielectric grease on the metal contact that connects to the ignition coil have to do with the VSC light coming on?
Thanks again, the car is running like a champ. Overdue by 20k miles but the old plugs were looking good still.
On the driver side, remove 2 bolts that hold the harness and pull it back with a tie wrap and you will have free and clear access to the 3 ignition coil plug bolts.
I have done all my cars' plugs (except the RX which I will not attempt to do), the IS is comparable in complexity but after reading through DIY's and prepping good, was not bad at all.
I recommend a point by point check before starting the car. I must admit, I was ready to start it up and came back and checked again, I missed 2 things, the Air Flow sensor connector and the vacuum connector for the intake. I could have pull multiple CEL's if I started the car!
Check and re-check.
I ended up coloring all the connections so next time, I will know which to check.
Safe than sorry.
Check and re-check.
Safe than sorry.
