Black Emblems
Yeah, very pricey at the dealerships. If you want to save money try this method:
https://www.clublexus.com/forums/aut...e-emblems.html
It's an identical look to the OEM black pearl emblems. I did this for my front and it matches perfectly with my rear OEM black emblems.
http://is.sewellparts.com
Cheapest method is to paint them. However, the paint will start to fade and chip off. My brother did the paint method on his GS and it looks like crap after a year or so. So I just went ahead and ordered my set from sewell.
You can get them on Sewell Lexus online.
http://is.sewellparts.com/accessorie...S350-2008.html
It will be a little bit cheaper with CL discount.
Not if you prepped though, properly. The front emblem will take beating....but the rears should be solid for a long time.
Check this thread out about painting the grill surround. Same concept on relatively the same material.
https://www.clublexus.com/forums/is-...sperate-3.html
I then did a search on plasti-dip and if I were to paint it, I'd use this because it is reversible.
Yes, definitely true on the front emblem. I DIY my front and it does take beating to the point where I want to try a different method.
i3urton
Jul 4, 2008 01:30 PM
