Will those wheels fit? START HERE.
Old Feb 23, 2012 | 03:15 PM
  #3196
Mike311's Avatar
Mike311
ive got coil-overs and want to go pretty low.
do u think if i put a 245/35/19 on the back i could go low and have no issues?
Old Feb 23, 2012 | 03:18 PM
  #3197
projectdna's Avatar
projectdna
Originally Posted by jgonx213
i was wandering if i go 19x11 +25 rear, and gonna put 245/35/19 on them, will they fit?
after roll or shave fender/ and slight pull?
it's about the same amount of fender work required as if you were running 10.5 +22.
and you'd have to run the same tire size.
Originally Posted by Mike311
19x9.5 + 35 for the rear. will this fit with no fender mods, what size tire you reccomend ?
cheers
Originally Posted by rookieIS
Depends on how much you're dropped.
For stock height no mods needed, tire size 265/30/19.
i'd push it and go 275/30-19 at stock ride height.
lowered, 255/35-19.
Old Feb 23, 2012 | 03:40 PM
  #3198
jgonx213's Avatar
jgonx213
do u think ill clear 19x11 +25 on the rear with 255/35 19?
with roll/shave fender and slight pull?
Old Feb 23, 2012 | 03:44 PM
  #3199
Mike311's Avatar
Mike311
Originally Posted by projectdna
lowered, 255/35-19.
so 255's lowered? with no fender mods? cause the shop i am ordering them from is telling me +35 offset on a 9.5 wheel wont fit in the back, but i cant see that being true because alot of you guys run way more aggresive offsets.
i just wanna make sure they will fit, lowered on coil overs with no fender work before i give them the ok to order the wheels.
Old Feb 23, 2012 | 04:27 PM
  #3200
projectdna's Avatar
projectdna
you'll need the stretched tires for fender clearance, so i'm not sure 255's will stretch enough on an 11" wheel, though if you roll the fenders flat enough (along with a pull) you might be able to.
19x9.5 +35 + 255/35-19 should fit in the rear without fender modifications.
some guys run even more aggressive offsets because they've got fender work done. but that doesn't mean it's not possible to run wider-than-oem wheels in the rear without the need for fender work.
Old Feb 23, 2012 | 06:01 PM
  #3201
steezy's Avatar
steezy
you'll need the stretched tires for fender clearance, so i'm not sure 255's will stretch enough on an 11" wheel...
Youre right, go with 245. Its not as bad as you think.
Old Feb 23, 2012 | 07:37 PM
  #3202
Saad1's Avatar
Saad1
projectdna, alright so I've got the +30 Varrstoens!
9.5x19 +30 F
10.5x19 +30 R
Now, I'm dropped on http://www.meganracing.com/product_d...d=542&catid=46 but my shop is telling me that my springs give too drastic of a drop if I don't want to do extreme stretching.
I thought I might ask you for help lol.
1) Should I change my springs? I'm currently at 1.25" with the Megans. See https://www.clublexus.com/forums/sus...d-for-2is.html for diff. drop heights. You think the Megan is too drastic?
2) I don't want PERFECT fitment of the tires.. I actually kind of like the stretched look. But I want the mildest stretch possible. What tire sizes do you recommend?
Thanks!
Old Feb 23, 2012 | 07:57 PM
  #3203
projectdna's Avatar
projectdna
9.5x19 +30 F
10.5x19 +30 R
Thanks!
1. no.
2. 235/35-19 up front. i want to say 265/30-19 in the rear, but you're safer off with 255/35-19. i think another member is running the same set-up and ran the same without fender modifications, but he was at a lower ride height and eventually needed to roll his rear fenders.
Old Feb 23, 2012 | 09:08 PM
  #3204
Saad1's Avatar
Saad1
1. no.
All my fenders are already rolled, just not pulled.. what sizes should i go with then? Look at the diff. between these 2:
Non-stretched tires
http://varrstoen.com/blog/?p=848
Stretched tires
http://www.street-cover.com/2011/ric...xus-is250.html
I think the first one looks absolutely horrible. I'd like to have the 2nd link look. I know that i don't have +22 like the 2nd link, but I'd like to get as close as possible to it.
Btw I'm asking all these questions cause I'm ordering my tires from an online source, as they're much cheaper online. So I want to make sure I get my tires right on the first try.
Thanks!
Old Feb 23, 2012 | 09:59 PM
  #3205
projectdna's Avatar
projectdna
Non-stretched tires
-link snip-
Stretched tires
-link snip-
Thanks!
this guy ran the EXACT SAME SPECS you are running, minus rolled fenders.
what he posted regarding tire size:
Originally Posted by White350
the wheels are +30 all around 255/3519 in the rear and 235/3519 in the front
(bolded for emphasis)
and since all of your fenders are rolled, go with 235/35-19 + 265/30-19.
Old Feb 24, 2012 | 05:36 PM
  #3206
Vroomin350's Avatar
Vroomin350
dna, will the fsport stock wheels fit over my 350 front brakes?
Old Feb 24, 2012 | 05:41 PM
  #3207
projectdna's Avatar
projectdna
F-Sport wheels? yes, they'll bolt right up and clear the oem IS350 calipers.
OEM IS-F wheels? no, they'll need spacers to clear the oem IS350 calipers.
Old Feb 25, 2012 | 02:35 AM
  #3208
jgonx213's Avatar
jgonx213
i talked to tony on so cal northridge who roll fenders
and he told me, if i go 19x11 +25 and 245/35/19, he said ill need camber kit? do i need camber kit?
Old Feb 25, 2012 | 08:53 AM
  #3209
Saad1's Avatar
Saad1
Alright ordering tires today. But won't the 265/30-19R give LESS of a stretched look than the 255/35-19?
I'm going for http://www.street-cover.com/2011/ric...xus-is250.html look over the http://varrstoen.com/blog/?p=848 look.
Also, what brand of tires do you recommend ordering? I've heard that General UHPs ( http://www.onlinetires.com/products/...p+93w+bsw.html ) are pretty reliable when stretched but how much faster will they wear out than the more expensive brands such as Continental, Dunlop, etc.?
Thanks.
Old Feb 25, 2012 | 11:48 AM
  #3210
projectdna's Avatar
projectdna
that, or you get a good pull when you roll your fenders.
Thanks.
the 265 is that much wider, despite being slightly shorter. 255 on 10.5 isn't that much of a stretch and is within safe limits, and the sidewalls won't be as upright. you really could do either or and still be okay.
i personally don't have much opinion on tire brand/model - i'll run almost anything, especially since i haven't stuck with a set of wheels and tires for an extended period of time.
but for outright, hands-down street tires, i'd go w/ PS2's and hankook evo v12's.
