Will those wheels fit? START HERE.
Old Mar 6, 2012 | 02:36 PM
  #3256
laobo979's Avatar
laobo979
Kevin your gonna need a roll,good pull, tab relocated up front, 225-35 front and 245-35 rear.
Old Mar 6, 2012 | 03:40 PM
  #3257
projectdna's Avatar
projectdna
^ what he said.
Old Mar 6, 2012 | 07:24 PM
  #3258
Kevin.IS's Avatar
Kevin.IS
^ Thanks guy
Old Mar 6, 2012 | 07:36 PM
  #3259
Saad1's Avatar
Saad1
projectdna I'm back to bug you
Alright so I've got:
+30 Varrstoens
9.5x19 235/35-19 front
10.5x19 265/30-19 rear
Rolled fenders + Tein S-techs.
Now I'm thinking of getting Roadmagnet springs that will drop my car down to this:
https://www.clublexus.com/forums/is-...ell-shoot.html
2.0" drop all around. But I noticed he had higher offsets. Will my current wheel and tire setup be able to fit these springs in without rubbing?
Edit: Also, will I need to relocate my fender tabs? And how would I check if I need to? Will it start to cut my tire or something?
Thanks.
Old Mar 6, 2012 | 11:57 PM
  #3260
projectdna's Avatar
projectdna
+30 Varrstoens
Thanks.
you might be able to.
relocating the fender tabs was a few pages back, i think...
Old Mar 7, 2012 | 08:41 AM
  #3261
Fuzzie's Avatar
Fuzzie
what tire size should i run being slammed on 19x8.5 +30 and 19x10 +38?
will i need to raise my car a little? currently slammed on 18s...
Old Mar 7, 2012 | 08:25 PM
  #3262
projectdna's Avatar
projectdna
225/35-19 + 265/30-19
Old Mar 8, 2012 | 03:21 PM
  #3263
Fuzzie's Avatar
Fuzzie
thanks. i wont need to stretch the tires right?
Old Mar 10, 2012 | 10:09 PM
  #3264
ZeroSeVen's Avatar
ZeroSeVen
Default What tire size do I need?
2012 IS250
Lowered on Megan coils with about 1.5 finger gap on all four corners.
Wheels: Concept One CS-10s light concave
20x9 with a 36mm offset front 20x10.5 with a 45mm offset rear
What would be the most ideal tire size?
Fender modification necessary?
Thanks in advance!
Old Mar 12, 2012 | 08:24 AM
  #3265
07awdis250's Avatar
07awdis250
I need some help. I want to know if these wheels will need any fender mods dropped on Road Magnet 2" all around ? My car is awd.
Front 20x8.5 +32 offset
Rear. 20x10.5. +30 offset
Which tires should I run? Thanks guys
Old Mar 12, 2012 | 06:23 PM
  #3266
speedstar's Avatar
speedstar
I know, relocate front bumper tabs, remove fender liners, roll fenders, stretched tires
pull just a little? i hope.
pull a lot? i hope not, but hey..
will these fit.. if not, how can i make them?
20x10.5 +2 Medium disc
20x12.5 +2 High disc
Old Mar 12, 2012 | 08:38 PM
  #3267
Kevin.IS's Avatar
Kevin.IS
Just got a quick question on sizing. So I bought a set of wheels with the following size:
19x9.5 +35
19x10.5 +35
Now the question is, the seller that I bought it from specified that the effective sizing is exactly the same as:
19x8.5 +22
19x9.5 +22
After doing some math I'm not completely sure why it is exactly the same. 1inch is 25mm so if 8.5->9.5 will yield a 25mm difference. Be easy on me, I'm still learning =/
Old Mar 12, 2012 | 09:29 PM
  #3268
07awdis250's Avatar
07awdis250
Can anyone help me? I'm lost!!!
Old Mar 12, 2012 | 09:42 PM
  #3269
laobo979's Avatar
laobo979
For the awd to be with the 1% diameter allowed go with 225-30-20 front 255-25-20 rear. I think a good roll is all you'll need.
Old Mar 12, 2012 | 10:20 PM
  #3270
projectdna's Avatar
projectdna
19x9.5 +35
19x10.5 +35
19x8.5 +22
19x9.5 +22
let's see if i can't answer this is 1,000 words or less...
we all know what offset is: distance between center line of wheel and inside mounting pad.
there are also two measurements that can be calculated from the wheel width and offset, and it's called the "frontspacing" and "backspacing".
frontspacing is the distance between the inside mounting pad and the outside edge of the wheel, and backspacing is the distance between the inside mounting pad and the inside edge of the wheel.
without boring you with math, what your seller has told you is basically this: your new, wider wheels have the same frontspacing as your old, narrower wheels. obviously, the backspacing of your new wheels will obviously greater than that of the old wheels.
thanks for reading.
