Will those wheels fit? START HERE.
Before I pull trigger, planning to get, F - 9.5 +22/R - 10.5 +22 for IS350, Car will be dropped to no gap. What will be needed to make this fit? Just fender roll and no fender pull right? Please chime in experts! :-(
Thank you for the clear explanation.
If possible, can you tell me what is an ideal camber/toe setting for my front and rears that will prevent rubbing whenever i go over a bump/dip/fast sharp turns(applies to front) without fender mods. I don't know if it is possible but I want to be rub free with 0 finger gaps all around.
*edit:
My sizes
18x8.5+31 with 225/40/18
18x9.5+31 with 255/40/18
*edit:
My sizes
zero out the toe.
Opps, that was a typo, yes 225/35 I was referring to.
2 possible tire configs I may go with:
- 19 x 8.5 + 42 Fronts / 19 x 9.5 + 45 (with 265/30, or stick with the 255/35 for rears)
- 19 x 8.0 + 40 Fronts / 19 x 9.0 + 40
Attached is the Work Wheels Japan's wheel match up for IS 250 and XSA-03C wheels.
the conservative offsets will allow you to run wider-than-oem-sized tires without clearance issues.
I just bought some new wheels, 9.5F and 10.5R, +22 offset, and I have my fenders rolled. I am also dropped on Megan springs ( http://www.amazon.com/Lexus-Megan-Ra.../dp/B005C6F214 ).
I do not want to fender pull, nor stretch my tires, nor camber arms because I don't want to change tires every few months. I am about to change my springs to probably Eibach if needed, as they give less of a drop ( https://www.clublexus.com/forums/sus...d-for-2is.html ), so that's prolly the only thing I can do lol.
What size tires should I run in order to not rub?
not going to happen with those wheel specs.
to be continued...
those specs aren't for 2is owners not looking to do fender modifications and/or stretch tires.
since you aren't looking to roll your fenders AND run stretched tires, only way you'll get by is to go back to stock height, since the instant you lower your 2is you'll have clearance issues.
let this be a warning to those looking to run wider-than-oem wheels with aggressive offsets. if you want to play, you've got to pay.
you'll also need to run 225/35-19 + 245/35-19.
235/35-19 + 265/30-19 might be possible if your rear fenders are pulled enough.
steezy is right. you bought the wrong sizes.
If i keep my +22 and I do stretch the tires, how often would I be replacing my tires due to wear? I tried googling but couldnt find much info. Keep in mind im gonna make sure my toe is good.
Also, is it possible to run square set up on RWD is250? like 9.5 all around?
Lastly, if I go swap for +30 tmrw, just my fender roll should be good.. no pulling or tire stretch required right?
Thanks for helping out a noob!
Alright that's no problem, I personally know the guy who I bought from so I'll go drop by tomorrow and swap em for some +30s. A few quick questions before I go do it tmrw though..
2. it is possible to run a square set-up, but then running staggered tire sizes will create different aesthetics. some mind, some don't.
3. even if you swap for +30 tomorrow, you'll still have to do some light tire stretching, but it'll at least be safe for daily driving.
word of wise, figure out how you want your wheels to fit before buying them, rather than buying wheels and finding out that you need to do all this work that you don't want to do (stretch tires, roll fenders) to make the wheels fit.
and my guess is, you're looking at a set of varrstoen's?
1. with a dead-on alignment, the fact that you are stretching the tire sidewall and causing undue stress and pressure on it will cause premature sidewall deformation and failure. when it will happen depends on how often you flip your tires and your driving habits. given that your 2is is lowered, the change in camber specs will cause the inside shoulder (and part of the sidewall) to be subject to those forces. it'll wear faster there and run hotter as well, and tire sidewalls are simply not reinforced in that area to support that kind of use/abuse.
Any guesstimate on how many miles I can make those stretched tires last on +30?
And yeah, haha. Was gonna with Volks, but an accident screwed me over and those are no longer within budget. (The accident wasn't my fault, but since it was in a parking lot no one was legally at fault, so I had to pay out of pocket.)
Sorry for the double post, but I did some digging around and discovered these IS's on +22..
http://www.street-cover.com/2011/ric...xus-is250.html
and
http://www.stancenation.com/2011/09/20/less-is-more/
They don't seem to have any pulling.. My question is, is their tire stretching too extreme for daily driving or something? What am I missing here? Seems like EVERYONE with varrstoens has +22 lol. Surely they can't ALL have fender pulls..
Thanks!
and
Thanks!
i feel for your situation, but my recommendation is, save up for the wheels that you want and can accomplish what you're looking for (no fender mods, no tire stretching) versus getting a set to get you by but may require doing what you don't want to do.
it seems like you want to do the least amount of fender modifications as possible and safely stretch tires over a set of wheels, and that tells me that you're not ready for varrstoens. as such, take those wheels back to your friend and get a refund.
on a related note, fender work is typically permanent and, short of replacing them with brand new sheetmetal, irreversible. i understand doing it for a baller set of wheels, but varrstoens? baller set of wheels, they are not. even if you are ready for a set of semi-aggressive-spec varrstoens, doing all that work for replica wheels doesn't seem all that worthwhile.
/$0.02.
/$0.02.
/$0.02.
/$0.02.
1. do you know where I could find pics of a square set up?
2. Any guesstimate on how many miles I can make those stretched tires last on +30?
3. What am I missing from the 2 links I provided... they have +22 but how come they don't seem to have any fender pulls, yet at the same time not too extreme stretching..
Thanks again for the help!! I won't bug you anymore after this lol.
Haha I get what you're saying, but I got a freaking amazing hookup on these wheels, so I'm happy for now lol. Besides, if I do fender work now, I'll be prepared for a couple of years down the line when I graduate and finally save up enough for some baller wheels. I'm OK with fender rolling at this point. Just a couple of questions now:
2. hard to say. alignment specs, driving habits, and even tire type determines how much life you'll get out of your tires. but if you plan on getting symmetrical tires, get them flipped from side to side once so every often to maximize the life of the tires.
3. the pull is enough to allow for fender clearance, but not enough to disturb the fender creases and lines.
i try to provide helpful advice, but at the end of the day, it's your money, it's your wheels and tires.
1. not really. but you can find pics of people who are running those specs either in the fronts or rears (i.e. 8.5/9.5 +22, 9.5/10.5+22).
However, I've kinda realized that since I'm going with springs, my drop will be permanent and I can never adjust anything without coilovers. Thus, i dont wanna push the limits with +22.. I might get stuck with an undriveable car. Sooo I guess I'll go swap for some +30s tmrw, and then come back for tire size advice lol.
Thanks!
