installing 2IS tail lights
Old Nov 4, 2009 | 01:51 PM
hybridanim's Avatar
hybridanim
Default installing 2IS tail lights
Is there a thread on here or manual that tells how to remove the 2IS taillights? Thanks.
Old Nov 4, 2009 | 02:31 PM
acefalcon2's Avatar
acefalcon2
for the outer tails.. remove the trim pieces and remove the 3 nuts... then pull out... for the inner taillight remove teh trunk trim too then remove 1 nut... and to the side of the trunk there are like 2 plastic nuts... all are 10mm nuts
Old Nov 4, 2009 | 02:55 PM
hybridanim's Avatar
hybridanim
dope!! Thanks! appreciate it!
Old Nov 4, 2009 | 03:01 PM
projectdna's Avatar
projectdna
note that the outer tail lights may be difficult to remove. anticipate using lots of "elbow grease".
Old Nov 4, 2009 | 06:58 PM
DaKi3241's Avatar
DaKi3241
ah i had this question a good 3 months ago. its pretty easy and self explanatory. If i had to say, the hardest part would be.... the unplugging of the wires process. it may be a bit hard to reach here and there and push the locks in the right direction to unplug them. other than that, quite easy! you will do fine, and good luck!
(I hope you got the F tails xD, or LED both is great )
Old Nov 4, 2009 | 07:03 PM
nmpeter's Avatar
nmpeter
^^ Yeah very self explanatory, just remove the carpet and you'll see everything you need to take out. For the others plyers may be useful.
Old Nov 4, 2009 | 08:01 PM
GiantsFan's Avatar
GiantsFan
It does take some effort to pull it off.... Dont be afraid, you wont break it
Old Nov 5, 2009 | 10:26 AM
hybridanim's Avatar
hybridanim
thanks guys! i got the LED ones, i was contemplating about the F, but led was cheaper and it comes with all four units.
Lveyolfe
Feb 28, 2017 11:05 AM
TjsLS400
May 28, 2016 08:01 PM
dajwilson
Jul 13, 2011 06:50 PM
pudieinpa
Aug 14, 2005 04:43 PM
