auto air circulation button
Old Jul 9, 2009 | 09:35 PM
soupdawg's Avatar
soupdawg
Default auto air circulation button
if its on auto what determines what mode the car will use?
Old Jul 9, 2009 | 10:23 PM
iKenn's Avatar
iKenn
Just call me "Sprinkes"
Smog in the air quality and/or your temp settings.
(i think)
Old Jul 9, 2009 | 11:42 PM
4U2eNv_8o8's Avatar
4U2eNv_8o8
I'm not to sure if it has to do anything with the air quality outside, but when ever I have the temp at 60 for a while then switch it to 70, the circulation opens to outside. To my understanding, the auto just opened up to move the interior temp to 70 quickly. I might be totally wrong, so someone correct me if needed to. Then again, I do live in Hawaii so all we get outside of our cars is warm weather all around.
Old Jul 10, 2009 | 05:34 AM
Koz's Avatar
Koz
It is determined by settings and sensors in the system.
Koz
Old Jul 10, 2009 | 07:06 AM
rac2max's Avatar
rac2max
Koz
LOLx....I don't know so can't help you here
Old Jul 10, 2009 | 08:23 AM
Bichon's Avatar
Bichon
(i think)
I agree. If the smog sensor detects fumes, or if the actual cabin temperature is more than a couple degrees warmer than the temperature setting, the system will select recirculate mode. Otherwise, it will select ventilate.
Old Jul 10, 2009 | 01:43 PM
15951's Avatar
15951
It will also switch from recirc to outside air if you pass gas. Go try it and report back.
Old Jul 10, 2009 | 10:21 PM
4U2eNv_8o8's Avatar
4U2eNv_8o8
Hahaha!!!! Are u serious?! I never tried this or ever noticed this when I pass gas. Curiosity is starting to sink in.
Old Jul 11, 2009 | 03:05 AM
i3urton's Avatar
i3urton
yes there is even a setting to how sensitive the sensor will detect smog...
Old Jul 11, 2009 | 03:40 AM
Kevin.IS's Avatar
Kevin.IS
It'll adjust depending on your temp setting. Say if you set the temp at 65 and its 70 inside it'll adjust it until it is 65.
Old Jul 11, 2009 | 10:16 AM
Audiofan2's Avatar
Audiofan2
If you do, press the fart button, unless you have passengers in the car to annoy.
687Jim
25
Aug 8, 2016 09:42 AM
scfz1000
RX - 3rd Gen (2010-2015)
Nov 22, 2013 11:38 AM
sas
Oct 29, 2006 10:47 PM
Mike_TX
Jul 17, 2006 05:17 PM
lexusdr
GX - 1st Gen (2003-2009)
Mar 6, 2005 09:33 AM
