Idle Vibration
Old Jun 25, 2009 | 08:54 AM
ajfinoak's Avatar
ajfinoak
Default Idle Vibration
Wondering if anyone has experienced this and had it fixed? My '08 IS 250 with 13K miles periodically after warm up has the idle drop to 500-600 RPM accompanied by a vibration in the steering wheel. Lexus Service had a Lexus Rep check it out who saw it happen and says it is "normal" but that they will look into it further as apparently I am not the only one with this. If it was a 4 cylinder, i would say maybe it is normal but I have never had a 6 do this including my previous ES 300 or various Acuras- disconcerting.
Old Jun 25, 2009 | 09:05 AM
jc86's Avatar
jc86
had this on a 4 cylinder on my old accord... i just accepted that it was normal
no problems here on my 06 IS250 with 64k, but i did experience it on my bmw 540i...and that's 8 cyl...so... =T
Old Jun 25, 2009 | 10:37 AM
Lexasaurus's Avatar
Lexasaurus
It happens to me if the i'm running low on fuel, but that's about it.
Old Jun 25, 2009 | 11:04 AM
J_Hao's Avatar
J_Hao
Mine does the same thing when comes to a red light. I took it to the dealer, and they said they needed to collect the data and report to the lexus. They will get back to me soon. still waiting for response.
Old Jun 25, 2009 | 11:22 AM
blue_dlb's Avatar
blue_dlb
Unfortunately this is normal which is horrible.
https://www.clublexus.com/forums/is-...e-in-gear.html
On my old es300 i couldn't even tell the engine was on.
Old Jun 25, 2009 | 12:02 PM
sktn77a's Avatar
sktn77a
It's not normal. But it may be a common problem. Something's amiss with the fuel delivery by the sound of it (computer, sensor, etc).
Don't let up on them - the car should idle faster than this and as smooth as a baby's behind! Mumble something about "emmission system failure" and "I wonder if the California Air Resources Board will be able to help"............................. (are you in California or Canada?)
Old Jun 25, 2009 | 12:37 PM
rac2max's Avatar
rac2max
get a manual and you don't feel a thing
Old Jun 25, 2009 | 01:22 PM
pocky's Avatar
pocky
mooncake master
I just accepted it as normal. My 2002 TL-S does this also. But then again, it did many more weird things.
Old Jun 25, 2009 | 02:09 PM
Fizzboy7's Avatar
Fizzboy7
Does the idle stay at 500-600 rpm or jump back up to normal? After my car has sat for a long time and I start it the next morning, it idles very high, then drops when warmed up. When it comes down to normal, sometimes I feel a slight bump as it settles to the normal rpm. Every car I've had does this, so I am used to it. Sounds like yours is doing something worse...
Old Jun 25, 2009 | 02:51 PM
pocky's Avatar
pocky
mooncake master
So on this subject. WHILE my car is warming up to it's optimal operating temperature. My idle usually sits at 500-600 at a stop light. But I think you also need to factor in who uses the A/C 24/7 and who doesn't. A/C will bump the idle up.
Old Jun 25, 2009 | 03:22 PM
juice14's Avatar
juice14
change your oil maybe?
It happens to me after installing the aftermarket exhaust. once the engine warms up it goes away some but not 100%
Old Jun 25, 2009 | 03:44 PM
ltran's Avatar
ltran
mine does that at stops too. i'm so paranoid, i always look back to make sure it wasn't some idiot who just rammed into me. lol
Old Jun 25, 2009 | 03:46 PM
ajfinoak's Avatar
ajfinoak
My car is stock and the vibration shows up regardless of gas level or if the oil was recently changed or not. Vibration with low idle show up periodically when fully warmed up, no A/C running (does not happen when A/C on as idle appears slightly bumped up).
J Hao- which dealer in CA is looking into it- I am going to Colliseum in Oakland and they have been dealing with Lexus western service rep on this.
Old Jun 25, 2009 | 06:56 PM
J_Hao's Avatar
J_Hao
longo lexus in el monte.
vadpink
Nov 24, 2024 10:09 AM
trdsw20
Mar 30, 2021 08:48 AM
jj813
IS F (2008-2014)
Nov 11, 2013 09:56 AM
ajfinoak
Apr 9, 2010 12:51 PM
silver02RX300
RX - 1st Gen (1999-2003)
Dec 15, 2001 05:48 AM
