AGGRESSIVE ISX50 wheel thread
Old Aug 16, 2012 | 10:02 AM
  #1651
ccdan's Avatar
ccdan
Originally Posted by ohiois350
hi guys, i wonder that anyone can fit 19x10 up front, and what offset could that fit without major fender mod? thanks
19x10 +25 would work.....19x10 +32 would be money and may work however I've only check it in 18" and the spindle changes shape per different diameter of wheels so where a 18x10 +32 clears a 19x10 +32 may not.
Here's the 18x10.5 I'm running up front with a 245/35/18 no roll or pull.
Old Aug 16, 2012 | 11:47 AM
  #1652
ohiois350's Avatar
ohiois350
Wow, the reason i asked is i am thinking getting the 19x10 all around for my IS350 and the wheels i like is cv3, i know they has 19x10 with 38+ that fit the rear, i wonder that offset would fit for the rear too? Or the lowest i can go 19x10 with 32+?
Old Aug 16, 2012 | 01:36 PM
  #1653
ccdan's Avatar
ccdan
Front
Actually the opposite the highest offset would be a +32 which is really in the grey area. so at minimum you'd need a 6mm spacer with a 19x10 +38 to kick it to a +32 to clear. This is fine on the stock studs. If for some reason it hits it would barely do so; a 8mm spacer would then be the trick.
Rear
Would bolt on a be fine. however you may want to add whatever thickness spacer your running up front to keep the rears from looking sunk. I'd suggest even a thicker spacer than 6-8 personally as 19x10 +38 is pretty wimpy.
Old Aug 16, 2012 | 02:47 PM
  #1654
ohiois350's Avatar
ohiois350
Front
Rear
thanks, would 19x10 with +30 all around would be perfect for my 350? what size the tires you ran on your set up?
Old Aug 16, 2012 | 03:55 PM
  #1655
TrancEpimp's Avatar
TrancEpimp
Originally Posted by SD.IS
Dude how are you running 215/35 on a 9.5. I run a 225/35 on my 9.5 in the front and I'm already iffy about the seal popping if I hit dips and stuff.
I run 215 on 19x9 up front with low teen offset's.. feels good to me and no problems!.. We have shops here in NorCal who specialize in fitting stretch tires...
Old Aug 16, 2012 | 04:30 PM
  #1656
MashinA's Avatar
MashinA
Well its not exactly recomended lol. Most tire shops wont touch my car. But ive had them on for a while with no problem.
Old Aug 17, 2012 | 05:20 AM
  #1657
Barker's Avatar
Barker
Originally Posted by Dimitri
dan, how big are the lips? I wish you made a 19", i'd be on it in a second.
here is mine with 19x11 +17
how much rear fender work did you need to do?
Old Aug 17, 2012 | 05:53 AM
  #1658
laobo979's Avatar
laobo979
Barker if you read his other post those aren't 19x11+17. He actually running a 19x10.5+22 as it was in the classifield. https://www.clublexus.com/forums/whe...step-lips.html
Old Aug 17, 2012 | 08:51 AM
  #1659
maximL's Avatar
maximL
I ran a 215/35/18 on 18x9.5 on my last car for over 2 year. No issues. It's really not that big of a deal.
Pic:
Old Aug 17, 2012 | 09:18 AM
  #1660
Vroomin350's Avatar
Vroomin350
Yea but thats an 8.5, hes running 215 on a 9.5
Old Aug 17, 2012 | 10:41 AM
  #1661
maximL's Avatar
maximL
Reread my post: 18x9.5
Old Aug 17, 2012 | 11:41 AM
  #1662
ccdan's Avatar
ccdan
That would be perfect. You'd be best with a 225, 235 up front which you could also run out back but you "can" run a wider tire on the back up to say a 275.
Old Aug 19, 2012 | 10:53 PM
  #1663
steeeven's Avatar
steeeven
Hey guys,
Sorry if this has been covered, but what tire size would you recommend for Front: 18x8 +31 Rear: 18x9 +37
If it helps I'm lowered on Megan EZ and have not had my guards rolled yet.
Old Aug 20, 2012 | 01:52 PM
  #1664
CCJ22's Avatar
CCJ22
Originally Posted by steeeven
Hey guys,
This is a broad question.
Before I can answer I must ask do you plan on lowering your car to damn near the floor?
Or will you have room for something like a 40series tire? (Just an example)
I can't help you until you help me
Old Aug 20, 2012 | 02:01 PM
  #1665
Quik208's Avatar
Quik208
Hey guys looking to place an order for a set of wheels this week and wondering what you think about these specs, or if there is anything you would recomend. I daily drive the car and want a semi agressive stance. Im ok with doing fender mods.
19x9 +32
19x10.5 +32
Currently riding at +1 finger gap up front and -1 finger gap in the rear. [Lowered on bc coils]
