AGGRESSIVE ISX50 wheel thread
Ccdan will you post more pics of your car, every angle please, your car is one of my fave here
How wide is your rear? I thought when you did 11.5 on mines was pushing it, but it end coming out perfect
Thanks guys.
Tires I'm running are Hankook Ventus V12's however in that photo it was a Falken FK452.
Dis350: I've have mocked up several setups on the car and with a stretched tire and still being able to have the rim tuck into the fender up to a 18x13 with a 315/30/18. Only issue with this is the tire selection is expensive and minimal with all really soft tires. 18x12.5 would be fine with the 295/3018's which come in better everyday prices and compounds but it left a decent gap between the sidewall and fender as it was "more stretch" than needed so I settled on the 18x12 with the 295/30/18 as it just looked and flowed better. Clears by the thickness of a business card or two.
I have also mocked up some non stretch tire setups such as a 18x11.5 with a 315/30/18 which fit more than fine as it fit as is and then I put 3/8" of spacers on it to sit flush.
Thanks guys.
I'm looking on swapping my f5452's..
Notice any difference on running v12? Do they run wider/ thinner? Are you able to get more negative camber or clearance?
18x10 with a 245/35/18.
never ran the FK452's on this car. had some in the past and they were loud but lasted awhile. The hankooks are awesome; lack in grip but cost less, are super quite, get great wear even with negative camber, and don't cup with the camber. they both stretch the same so the sectional width is on par the same between the two.
I can't get my 19x9.5's to stop rubbing.
You sir > me
Props
