AGGRESSIVE ISX50 wheel thread
Old Apr 21, 2012 | 08:13 PM
  #1576
kams229's Avatar
kams229
Originally Posted by MashinA
where in fl are u?
I'm in destin right between Pensacola and panama city beach
Old Apr 23, 2012 | 06:01 AM
  #1577
Whiteis250's Avatar
Whiteis250
I ordered xxr 521 18x10 with +25 offset all around. I was told that it wouldn't fit in the front. So i was told to go 18x8.5 in the front with 15mm spacers and 18x10 in the back. What do you guys think?
Old Apr 23, 2012 | 08:22 AM
  #1578
ccdan's Avatar
ccdan
Originally Posted by juvi22003
Might be a stupid question but what is the highest offset that u guys would considered aggressive?
offset can't be generalized. it literally means nothing without the width of the wheel. the reason being is it's calculated off the center line of the wheel so a 8 +25 and a 9+25 sit differently on the car. do you know what width wheel your wanting this question answered too?
fail! save up and buy some nicer wheels.
Old Apr 23, 2012 | 08:50 AM
  #1579
juvi22003's Avatar
juvi22003
It was just a general question, i also know how the offset is calculated. Im running agressive but not too agressive 19x9.5/10.5 +25 all round. As i said it was a general question.
Old Apr 23, 2012 | 09:33 AM
  #1580
Sango's Avatar
Sango
Question:
If I were to get 19" F-Sport forged wheels or IS-F wheels. Should I stick with stock IS tire size for the front?
For instance for IS X50s 19" fronts is 225/35/19. For the IS-F, it's 225/40/19.
Wonder if I could put a tire profile which matches the IS-F on the front. Implications? Rubbing?
Old Apr 23, 2012 | 06:46 PM
  #1581
ccdan's Avatar
ccdan
i know that's why i posted that. it literately means nothing without the other half of the question that's all. wasn't trying to be a ****. if you knew they why ask...
19x9.5 and 19x10.5 +25 is aggressive on the IS as anything lower offset than +22 will require more negative camber than stock or a pull to clear.
Old Apr 23, 2012 | 06:51 PM
  #1582
ccdan's Avatar
ccdan
Originally Posted by Sango
Question:
That's kind of odd that Lexus did that. wheel wells are the same other than the is-f fenders are wider but that shouldn't change the overall diameter. Don't see why it wouldn't be possible however it will be easier to get them to fit with the shorter 225/35/19 tire considering the fitment of the is-f or f-sport wheels will be a bit more aggressive.
Old Apr 23, 2012 | 06:58 PM
  #1583
UtoyZ's Avatar
UtoyZ
ccdan ~ i need your expertise, do you think 19x10 with mid-30s offset would fit in the front? would i still be able to make full turns without hitting anything?
any input would be much appreciated! TIA
Old Apr 24, 2012 | 08:04 AM
  #1584
ccdan's Avatar
ccdan
At +35 or higher yes with static camber. It's not even close to hitting lock to lock so you good there. You'll have around .375" of clearance behind the wheel at +35.
Old Apr 24, 2012 | 08:27 AM
  #1585
Sango's Avatar
Sango
The wheel size is the same. The only thing know which may play a factor is that the F-Sport wheel is 40mm at the front and the IS-F wheel's front is 45mm.
In relation of tallness using IS-F's front would make the front tire taller than the rear's by 1mm (which is bascially hard to notice) compared to 20mm shorter using the stock front.
I wonder if it is more of a look thing or practical thing. I guess the IS-F would fill the wheel well better.
Old Apr 24, 2012 | 04:59 PM
  #1586
ISRabbit's Avatar
ISRabbit
I also live in Destin. Miramar beach to be exact. What is your IS? I drive the red one with black lip.
Old Apr 24, 2012 | 05:11 PM
  #1587
is350FS's Avatar
is350FS
not nearly as aggressive as most on this thread but is what im rollin on for now, road magnets on 19'sAGGRESSIVE ISX50 wheel thread-465691_10150797815276894_585221893_11463505_1625986927_o.jpg
Old Apr 24, 2012 | 07:32 PM
  #1588
kams229's Avatar
kams229
I drive the sgm with black lip and polished face on bags
Old Apr 24, 2012 | 08:02 PM
  #1589
ISRabbit's Avatar
ISRabbit
Do you go to any of the car shows? Like the commando cruise? Don't mean to get in your business but are you a cop? I think I may have talked to you before. You were my inspiration for really wanting an IS. I mean I always liked them but always loved yours. Its clean as hell. I use to have the bright red IS300 on white work emotions, gold vs-xx's, bronze TE37's, enkei RPF1's, or polished CCW's one of those sets lol.
Old Apr 24, 2012 | 08:20 PM
  #1590
kams229's Avatar
kams229
No not the cop I know who ur talking about though. I run the wash in destin the one next to the Greek restaurant
