Help, grill thing
Old Dec 11, 2007 | 05:03 AM
Rash's Avatar
Rash
hmm
Default Help, grill thing
I think it's call weather strip or something. anyway I was bored, so I wanted to remove the grill, just for a try.
I have no idea how to return the strip thing back, I'm sure the solution is so dumb
can't wait to use the "" emoticon.
Old Dec 11, 2007 | 05:17 AM
Rash's Avatar
Rash
hmm
dont tell me I should not remove that rubber strip thing? oh god -__-
Old Dec 11, 2007 | 05:45 AM
MrMark's Avatar
MrMark
Feed one end of the elongated tab into the hole, pull in the opposite direction and feed the other end of the tab in....viola.....
Old Dec 11, 2007 | 05:48 AM
Rash's Avatar
Rash
hmm
that sounds so easy I will try it now.
removing the rubber thing is one of the steps removing the grill right? I removed 1/4 of it, and I got scared
Old Dec 11, 2007 | 06:24 AM
Pnuge88's Avatar
Pnuge88
hahaha i removed mine.. and i cant get em back on.. cause i took the whole dam thing off! hahaha oh well.. im buying a new grill anyways
Old Dec 11, 2007 | 06:26 AM
Rash's Avatar
Rash
hmm
its PITA! I put 1 tab on, but the end is impossible -__-
so If you get a new grill, you will throw away that rubber strap?
Old Dec 11, 2007 | 08:32 AM
italiandud's Avatar
italiandud
Is it really that necessary to clip it all back in? I just have mine layed on top...
Old Dec 11, 2007 | 08:55 AM
carlos's Avatar
carlos
that thing is so easy to put back on. get needle nose pliers and pull out the plastic and reinsert it into the rubber piece.
Old Dec 11, 2007 | 09:01 AM
1022it's Avatar
1022it
if you use pliers be gentle, you dont want to deform the plastic tabs that hold it onto the grille holes. they won't work anymore.
this rubber piece i am sure is to help quiet the vehicle, and you should always keep it on the vehicle. plus, it keeps a bunch of junk from getting into your clean engine compartment.
the clips keep it in place. spend the extra 10 minutesa nd do it right guys. :O
Old Dec 11, 2007 | 09:37 AM
Supershyguy's Avatar
Supershyguy
take the clips off from the car, install it back on the rubber piece before installing the whole thing back on the car
I have done it 10 times so this is the right way to do it.
(just dont break the clips when you are trying to pull it off the car)
Old Dec 11, 2007 | 09:41 AM
rfx45's Avatar
rfx45
Same here. I didn't really bother putting it back in the clips. I just laid it on top and closed the hood. It's not sticking out or anything and doesn't seem to cause any problem.
Old Dec 11, 2007 | 05:51 PM
Irishman06's Avatar
Irishman06
CL Folding 25,000
Yea, the way to remove these seals is to pull directly up where those tabs are inserted...that way the tab comes with the seal.
Old Dec 11, 2007 | 09:29 PM
ExclusivIS's Avatar
ExclusivIS
Now this sounds like the REAL way to do it. I'm going to try it tomorrow, thanks for that info.
nysupraman
IS F (2008-2014)
36
Feb 12, 2017 08:40 PM
dougm213
Dec 2, 2014 05:45 AM
OutkastGS3
Feb 20, 2009 09:50 AM
blkonblk17
Apr 19, 2007 07:12 AM
Styx
IS - 1st Gen (2001-2005)
Jul 17, 2004 11:35 AM
