AUX input sounds horrible
Old Sep 26, 2007 | 09:58 PM
iialcii's Avatar
iialcii
Default AUX input sounds horrible
I had my is250 for a month now, I finally decided to try the aux input in the arm rest, I hooked up my ipod, and the volume is all the way up, but the audio feed sounds like garbage. The sound seems like its unbalanced through the speakers, as if its just playing from one, the driver side.Does anyone else have this problem? is there a setting I can play with? I tried the differnt positioning feeds, like pos all, pos rear, pos front/driver which seems like there is not a differnence.
Old Sep 26, 2007 | 10:02 PM
CAIFAN_64's Avatar
CAIFAN_64
there is a tsb to fix this
Old Sep 26, 2007 | 10:13 PM
iialcii's Avatar
iialcii
do you know where the tsb is posted? or should i just ask the dealer. thanks
CAIFAN_64's Avatar
CAIFAN_64
I found it read this.........
https://www.clublexus.com/forums/sho...d.php?t=300319
Old Sep 26, 2007 | 10:15 PM
iialcii's Avatar
iialcii
thanks Bro!!! But I dont hear any noise just bad feed......
Old Sep 26, 2007 | 10:20 PM
Dj_AmtraX's Avatar
Dj_AmtraX
you need a connector from ipod dock to mini jack. Besides, ipods sound bad to begin with.
Old Sep 26, 2007 | 10:23 PM
iialcii's Avatar
iialcii
I picked up a double male end i think 2.55mm or 3.55 i forget. I do have the correct connection.... it just sounds really bad, and uneven
Old Sep 26, 2007 | 10:28 PM
weesped's Avatar
weesped
it should be a 3.5mm same size as headphones. but you should def get audio out from the dock since its constant and non variable like out of the audio jack. granted the best sound your going to get is still cd quality
Old Sep 26, 2007 | 11:09 PM
Hartawan's Avatar
Hartawan
Former Vendor
Check your ipod settings, maybe you have EQ on.
Old Sep 26, 2007 | 11:24 PM
iialcii's Avatar
iialcii
I already tried changing the ipod settings, and eq or generation like pop/rock/classical etc still the same. thanks though. ill montion the tsib on my next service. maybe it will help if they add the filter in. thanks CL
Old Sep 27, 2007 | 04:23 AM
yov6cam's Avatar
yov6cam
try the ground loop isolator, may clean up the noise more, but understand that whatever you do, the volume will never be as high or as clear as CD
Old Sep 27, 2007 | 04:50 AM
kattanh3's Avatar
kattanh3
Try turning the EQ off (or set it to none), this improved the sound output a lot! thanks Hartawan
Old Sep 27, 2007 | 04:59 AM
IS350jet's Avatar
IS350jet
I use a radio shack 1/8" mini male plug to a 1/8" mini male plug and it works great. The iPod sounds great when you burn at 192khz.
Old Sep 27, 2007 | 06:00 AM
papiti's Avatar
papiti
Dude Try 2 Things, on your i-Pod
1- Go To Settings and check the volume limit, put up all the way.
2 Go To Settings, turn OFF the Sound Check.
This will let the sound be higher.
Old Sep 27, 2007 | 06:35 PM
Xanadu350's Avatar
Xanadu350
You need the Sik Ram Din, it's so simple, this is really all you need. I bought this and I swear my iPod sounds almost as good as CD's. Remember for the iPod you will always get a clearer better sound using the dock (bottom) line out instead of the headphone jack (top)
If you get it at Amazon, it comes right from the people that make it SIK. (I got black cause my interior is black) I love this cable it sounds incredible in the IS.
http://www.amazon.com/black-FireWire...0942750&sr=8-1
Here in white
http://www.amazon.com/white-FireWire...943318&sr=8-15
If you don't want to order from Amazon, get it from the SIK here
but it;s the same place Amazon gets it anyway
http://www.sik.com/ram_din.php
The square (small rectangle connector you dont' use)
Best $20 bucks I spent (can I count this as a mod?)
