AUX input sounds horrible
Old Sep 27, 2007 | 06:41 PM
Evitzee's Avatar
Evitzee
Agree with previous post, don't use the headphone jack, it is garbage. Get the adaptor that plugs into the dock connector. You'll notice the differernce.
Old Sep 27, 2007 | 07:13 PM
as3.0cl's Avatar
as3.0cl
monster cable carcharger plus head phone jack through dock connector. plug into power source under the arm rest.
http://www.amazon.com/Monster-Cable-...0944990&sr=8-5
attached to monster cable jack 3.5 male-male belkin which then is then connected into an RCA noise filter that connects to the aux port.
3.5 stereo jack from the connection of the monster cable plugs into this:
http://www.crutchfield.com/S-8b0G3tJ...er&i=127SNI135
can charge it, plus use the doc connection for better clarity and remove all of the buzzing/hissing/wining sound.
thats my set up and it works perfectly
Old Sep 27, 2007 | 08:50 PM
iialcii's Avatar
iialcii
Originally Posted by yov6cam
try the ground loop isolator, may clean up the noise more, but understand that whatever you do, the volume will never be as high or as clear as CD
whats the loop isolator? how do i do that ? can you specify pls
if it doesnt work ill try purchasing a docking wire to 3.5mm.
i tried changing the volume limit on the ipod and sound check but still turn the volume on ipod to max and stereo to max its only playing like it would be at volume level 15. I like to play my music loud like 40-50 volume setting.
thanks for all the responses.
Old Sep 27, 2007 | 10:34 PM
Bichon's Avatar
Bichon
You only need the filter provided by the TSIB or the ground loop isolator if you are charging the iPod while listening to it. If you aren't using a charging cable, it won't help you.
I agree with the others that a cable that uses the iPod dock connector like the RAM-Din (lower cost alternatives can often be found on eBay) results in noticeably better sound than a headphone cable. That said, I did use the headphone cable before I got my dock cable, and didn't experience the problems you are having.
Old Sep 28, 2007 | 01:39 PM
Dj_AmtraX's Avatar
Dj_AmtraX
A picture speaks a thousand words.
Old Sep 28, 2007 | 02:04 PM
as3.0cl's Avatar
as3.0cl
read my post above you and click on the links, you should see what u need including the ground loop isolator.
and the IS's volume on low volume is very low for me, all toyota's seem like that to me though.
Old Oct 9, 2007 | 12:27 PM
iialcii's Avatar
iialcii
thanks everyone, I got the TSIB and the docking cable, sounds alot better.
hoosier1
Feb 13, 2014 08:04 PM
soupdawg
Jul 23, 2009 03:32 PM
swj123
Jun 7, 2007 01:46 PM
YYZlexus
Apr 19, 2006 07:46 PM
Ingoglia
Feb 24, 2006 05:58 PM
