low tire pressure warning light
Sep 15, 2007 | 09:03 AM
how do i turn it off? or disable this?
is the recommended pressure :
front: 35psi
rear: 37psi?
i have the 250awd.
thanks
Sep 15, 2007 | 09:32 AM
Quote:
Originally Posted by
freddymoo
front: 35psi
rear: 37psi?
i have the 250awd.
thanks
You can't.
Sep 15, 2007 | 09:43 AM
u sure i can't do it myself? i dont want to drive 30miles 1 way just to reset the light??
Sep 15, 2007 | 09:47 AM
are you sure your tire pressure isn't low? my light came on, i put air in the tire, and it went off immediately.
Sep 15, 2007 | 09:53 AM
Inflating my tires to the correct pressure is how I turn mine off. The correct pressure is found in the manual.
Sep 15, 2007 | 09:56 AM
correct pressure can be found at the driver door area....it should have a sticker which indicate the front and rear spec...
Sep 15, 2007 | 10:02 AM
mine came on too, but as soon as I inflated to the correct pressure, the light went off.
Sep 15, 2007 | 10:20 AM
If you want to keep them a lower pressure (a day at the track or whatever)...you can turn off the warning light by going into your options (the scrollable options on your dash).
Go to the screen that says initial tire pressure.
Press and hold the button to set the desired pressure to what it is now.
But still know that your tires are below what they should be.
Sep 15, 2007 | 10:25 AM
sykocus
..and inside the driver's door.
Sep 15, 2007 | 06:27 PM
I think page 283 in your manual explains how to reset this. Mine came on this week as well...due to the colder temps...I just made sure my fronts were at 35psi and rears at 37psi.
Sep 22, 2007 | 09:25 AM
mine low tire pressure did also turn on because of colder temps but after i reset them the low pressure light still stay on?? any suggestions?
Sep 22, 2007 | 11:27 AM
i3urton
What pressure did you put in your tires? Did you use a gauge?
Sep 22, 2007 | 12:07 PM
freddymoo
front: 35psi
rear: 37psi?
i have the 250awd.
thanks
Yes that's the recommended pressure - measured cold! There's a label on the rear of the driver side door jam stating the recommended pressure.
Sep 22, 2007 | 12:44 PM
errr from the dealer ship the tire pressure was 30.... i put them up to 38 on the rear and 35 on the front....no more low pressure warning.. ...im going to buy a air compressor.
Shrink
Dec 2, 2023 09:31 PM
Huskers 22
Oct 31, 2019 05:02 PM
Shrink
Oct 15, 2018 02:25 PM
lifeisgood
Sep 23, 2006 06:08 AM
firstls430
Mar 17, 2006 05:21 PM
2007 ,
350 ,
air ,
es ,
is350 ,
lexus ,
light ,
low ,
pressure ,
put ,
set ,
stay ,
tire ,
tires ,
turn ,
warning
