Uh oh... Please Help...
Old Jul 29, 2007 | 09:59 AM
jdoolitt's Avatar
jdoolitt
So the rev limiter in the IS works differently than most all other automibiles? Typically - a rev limiter cannot help in a downshift situation as it only cuts off fuel supply.. which will NOT help in a downshift situation - where you already have your rpms up.
Old Jul 29, 2007 | 10:32 AM
FiveOhNine's Avatar
FiveOhNine
Any auto transmission that doesn't know not to go from 6th to 3rd at 100 mph isn't worth its weight in scrap.
Auto transmissions don't misshift like that, only people do with sticks.
Edit: I have never heard of an auto doing that. It may have happened....?
Old Jul 29, 2007 | 11:29 AM
mikes rx's Avatar
mikes rx
I use "..." ....... a lot
Originally Posted by Bichon
Which begs the question, what happens if you flip the shift lever from "Drive" to sport mode when traveling 110 or faster? And no, I don't recommend anyone here be foolish enough to try it.
It will probably beep at you telling you that it couldn't do the shift, similar to how it does if you're in sport mode and keep tapping to downshift (into a gear too low).
Old Jul 29, 2007 | 05:52 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Add to this I'm dead sure this engine will take 7500 rpm with ease. The only thing that might get upset is the valve springs. Certainly not the bottom end or the rod bearings.
There is no way you hurt your engine.
juncho
Nov 28, 2016 02:32 PM
stlgrym3
Mar 11, 2015 11:54 AM
kl323
Apr 29, 2011 12:43 PM
Rider
Sep 13, 2010 05:06 PM
JYOO
Feb 22, 2002 09:25 PM
