Headlight Adjustment Success!
Old Sep 12, 2007 | 05:11 PM
  #76
Bass Mech's Avatar
Bass Mech
Originally Posted by dAiLL3sT
alright well ive looked for 20 minutes and i really cant find where the hell this horizontal thing is :S
ok try this, i havnt seen them in a while and i dont feel like taking the car apart right now, remove the front engine cover, lift the small black plastic cover that runs right along the edge of the fender and look under it, ithere should be a hole right near the top of the fender where the larger side engine covers end.
Old Sep 12, 2007 | 05:19 PM
  #77
dAiLL3sT's Avatar
dAiLL3sT
i appreciate the help man. but i have to say i am more of a visual learner i can not understand anything u have described. thanks alot tho man
Old Sep 12, 2007 | 05:20 PM
  #78
jimjaix's Avatar
jimjaix
I found the hole but I can't do anything with it, I tried using a screwdriver but it wont' turn in anyway, is there an easier way to adjust this piece of crap!!@!@ The vertical one is so easy to do...
Old Sep 12, 2007 | 05:21 PM
  #79
jimjaix's Avatar
jimjaix
If you know how to adjust it vertically, then just look to the Left on your Left HID and Right on your Right HID, there's a hole where you can put a screwdriver in and "turn" it but I couldn't do it. I found it but can't do anything to it
Old Sep 12, 2007 | 05:36 PM
  #80
Bass Mech's Avatar
Bass Mech
insert it at an angle that would place the top of the screwdriver right behind the low beam projector. it will stop and you should feel a slight resistance when turning it.
Old Sep 12, 2007 | 05:49 PM
  #81
jimjaix's Avatar
jimjaix
But then you can't see how many turns you did?
Old Sep 12, 2007 | 10:03 PM
  #82
CWS's Avatar
CWS
5 turns of the screwdriver = 1 turn of the adj wheel.
Note how many turns you did on the vertical, and do the same on the horizontal.
Old Sep 12, 2007 | 10:12 PM
  #83
jimjaix's Avatar
jimjaix
I feel like I wanna give up with the horizontal one and just take it back to the dealer. Why the hell did they make it so difficult for the horizontal geezzzz...
I got the vertical to work perfectly but now my light spray apart because I didn't do the horizontal...
Old Sep 13, 2007 | 06:41 AM
  #84
dAiLL3sT's Avatar
dAiLL3sT
i counted the teeth on the vertical....
and can please anyone im begging just take a picture and circle the hole in the program paint and post it???!?!?! i still cant effing find it!
Old Sep 13, 2007 | 06:58 AM
  #85
iSuxeL's Avatar
iSuxeL
This is from technique:
If you look on top of the adjustment screw you will see the cutout to where the horizontal adjusment screw is.
Heres another one that you can clearly see the hole.
Old Sep 13, 2007 | 07:08 AM
  #86
Bass Mech's Avatar
Bass Mech
there you go, both holes and pictures of them, now quit complaining and go adjust it.
Old Sep 13, 2007 | 07:31 AM
  #87
jimjaix's Avatar
jimjaix
nono, I found the holes already but I can't adjust it using my philips screwdriver with a 45 degree angle. Maybe I will just take it back to the dealer and have them do it
Old Sep 13, 2007 | 08:11 AM
  #88
dAiLL3sT's Avatar
dAiLL3sT
well i just did mine thanks for the pics... im not sure if i counted correctly lol ill have to see tonight or something but i was doing the counting by feel and wasnt sure if i did it in the correct way so yea thanks for all ur help
Old Sep 15, 2007 | 01:16 PM
  #89
FrankyJ's Avatar
FrankyJ
CL Folding 25,000
From: Sleep in Long Island, Dominican Parties in Queens
Can someone PLEASE PLEASE take pics of the vertical screws?
Old Sep 15, 2007 | 01:24 PM
  #90
rfx45's Avatar
rfx45
Those pics really helps. Thanks!
