Headlight Adjustment Success!
Old Aug 18, 2008 | 11:15 AM
  #106
BounceNY's Avatar
BounceNY
Originally Posted by caymandive
Any updates with this method?
I actually used that method, its really easy. The sensor is behind the rear driver side wheel. Need a 10mm socket. Once slightly loose, adjust the screw down for HID level to move up. I found more info on this in the suspension area somewhere after ppl kept having issues with AFS after lowering their cars. I think its similar in the GS model.
Old Oct 8, 2008 | 08:59 PM
  #107
USB_F's Avatar
USB_F
Can you post a pic of how low you actually went with the screw?
Old Oct 8, 2008 | 09:59 PM
  #108
crazybuggy's Avatar
crazybuggy
oh sweet! does this void warranty?
Old Oct 9, 2008 | 12:11 AM
  #109
punkatom's Avatar
punkatom
id love more info and pics on this too.
Old Sep 16, 2010 | 02:53 AM
  #110
ldc's Avatar
ldc
Originally Posted by genki
im still a little bit confused. does this one screw adjust both the horizontal and vertical aiming of the headlight?
Sorry to bring back a dead thread. But is there an answer to this question?
Old Sep 16, 2010 | 04:50 AM
  #111
Kurtz's Avatar
Kurtz
Yes. Both multiple times in this thread and in your owners manual under headlight adjustment.
Old Sep 16, 2010 | 05:45 AM
  #112
ldc's Avatar
ldc
Can't find it in the manual.
Old Sep 16, 2010 | 08:41 AM
  #113
Kurtz's Avatar
Kurtz
It's in there. Under the DIY maintenance- Headlight Aim section.
You can read that section yourself from an 06 manual here:
http://us.lexusownersclub.com/forums...howtopic=25999
Page 309 specifically in that years manual (or in that PDF)
Old Sep 17, 2010 | 09:29 PM
  #114
ldc's Avatar
ldc
I think the is250 menu is different, doesn't have it.
Anyway i can only find one bolt, and managed to leveled my headlights....thanks anyway.
Old Sep 17, 2010 | 10:01 PM
  #115
Kurtz's Avatar
Kurtz
You did it wrong then... there's 2 for each headlight.
The same headlights go on the 250 and 350.
You might have "fixed" the aim up/down but you've now misaligned the aim left/right in doing so if you only used 1 screw per headlight.
Old Sep 17, 2010 | 10:03 PM
  #116
ldc's Avatar
ldc
Can you take a photo of the two bolts. I can only locate one.
Old Sep 18, 2010 | 08:19 AM
  #117
Kurtz's Avatar
Kurtz
Did you look at page 309 in the PDF I linked you to? It shows the location of both bolts A and B and that you need to adjust both the same number of turns for each headlight.
IIRC for the second one you'll only see the hole to put the screwdriver into, not the bolt itself.
Old Sep 18, 2010 | 10:38 PM
  #118
ldc's Avatar
ldc
The other bolt is next to imposible to see and turn. It's a black hole lol.
Old May 31, 2011 | 06:50 PM
  #119
file82's Avatar
file82
I am still confused with the clockwise, counterclockwise thing.
If I want to move up the light, do i turn the screw driver counter clockwise to make the screw clockwise. Or the other way?
Old Jun 1, 2011 | 07:34 PM
  #120
ScKcBc's Avatar
ScKcBc
lmao at the OP. I've done this a few times and I dont count *****, I use a drill
