Fixed dash board rattle
Old Dec 12, 2006 | 05:35 PM
TorontoIS's Avatar
TorontoIS
Originally Posted by r1lee
I went and pulled mine out last night and left it out. If you empty your glove box.. you will see that tray/stand. Pull up and left.. that tray comes out.
Then at the back, you will see a black plastic panel. That's the panel that was making noise. Everytime I pushed on it.. it was making a noise.. so i dugged my fingers in and pulled it up and out and left it out. I think that has solved my problem.
If I put that panel back in, and push on it, it makes a squeeking noise.. Thanks to TorontoIS for pointing this out.
I'm glad it worked for you. When I picked up my car the tray/shelf in the glovebox wasn't properly installed and it worked itself out of place and was making noise. After installing that properly in its slots I thought I had the problem licked. Then I noticed a different noise which I assumed was from the dash, the one that has a TSB. However, in poking around the glovebox I noticed that pressing that panel at the back made a loud creaking/rattling noise. I lifted up on it taking it out of place and reinstalled it properly. Pressing on it then cause absolutely no noise at all. Driving over bumps now really is a non issue for noise because there is now no noise. I'm glad that the car is quiet again.
Old Dec 12, 2006 | 07:08 PM
r1lee's Avatar
r1lee
Originally Posted by mctuners
My 07 Is250 has the same sqeeking/ratling noise, which seem to be coming from close to the NAV unit. I only had the car for a month now and it makes me feel like I'm driving a civic. I tried to hear if it's coming from the glove box, but it's not. it is very clear to see it coming from the Nav unit. Should I remove it and put it back on with some electrical tape around it by hoping that it will make it fit tighter so that it doesn't squeak anymore?
if its something that is persistant, take it to the dealer. go for a test drive then tell them you want the car back squeek free.
Old Dec 28, 2006 | 10:02 AM
Peacefrog's Avatar
Peacefrog
I have the same rattling coming from, what seems to be, the NAV unit. Although with mine it is only really noticable when the car is cold, as it warms up the rattle goes away.
Old Dec 28, 2006 | 12:44 PM
dat-is350's Avatar
dat-is350
Originally Posted by javyLSU
I had a creak coming from the driver side air vent. After removing it, I discovered two small wires (about 25mm long) on the back of the vent. These wires have a material similar to electrical tape on them that was rubbing up against the base of the dashboard, causing the creak. I cut off the tape, and voila - no more creak!
Javier
I have the same rattle on the driver side air vent.. I'm going to have to try this. How did you take it out? Is it just clipped on? Thanks a lot
Old Dec 28, 2006 | 01:19 PM
javyLSU's Avatar
javyLSU
2IS OG
Just take the side cover off first, and once you have unfettered access to the vent, just pull it straight out (forcefully, but carefully). Something you guys also might want to watch out for are the tabs that hold the door panel on. I eliminated another creak when I discovered that the tab located closest to the rear view mirror on the driver's door panel wasn't properly engaged in the hole - it was squished flat, making the door panel protrude out and rub up against the dashboard. I've NEVER taken this panel off, so it came from the factory like that. I used a flathead screwdriver to guide the tab into place, and the panel sat properly, eliminating the creak.
Javier
Old Dec 28, 2006 | 01:27 PM
dat-is350's Avatar
dat-is350
Thanks alot Javy! Will have to try this as soon as my girlfriend gets home because it is annoying me so much. I'm also getting one from somewhere in the instrument panel. At first I thought it was the speaker area up top, but now I am unsure. Or maybe it's multiple areas. :Shrugs:
Old Dec 28, 2006 | 04:54 PM
lexudv's Avatar
lexudv
Noises, noises, noises!! I have an 07 and have the same problem. I have taken it 5 times and still no fix. And it's true the noise is more noticable when it is cold after you drive a while, which I have to do in order to get to the dealer. It goes away and you can barely notice it. This along with the perfect roads that are around Tustin Lexus makes it almost impossible to hear the sound when I ride with the technician. Mine sounds like it is coming from either the middle panel where the stereo is at or the front speaker grill right under the dash....
I'm going to take it to Glendale Lexus and if it's not solved by this time (The 6th time ) I think i'm going to have to call Lexus directly.
Everything else about the car is
Old Dec 28, 2006 | 05:02 PM
Technique's Avatar
Technique
CL Folding 500,000
So why do you care then? Is the noise that loud that you are that bothered for the few minutes it takes to go away? Not being hostile, just curious...
Old Dec 29, 2006 | 08:28 AM
gyung's Avatar
gyung
Rattles and stuff drive me crazy, so when my driver's side chair started having a creaking noise, I was pissed. A $40k+ car having rattles? Come on... Anyway the first time I took it in, they said a motor in the seat was crooked and they set it straight. But the noise was still there, and I had to take it in a second time.
I don't remember exactly what it was, but they said a plastic molding on the side of the seat was, uh, morphed or whatever, so they fixed it too. So with those creaking noises out of the way, I hear the one in the glove box one, so I'm gonna try to fix later today.
But I also have a rattle over certain types of roads coming from what seemed like the nav unit. After a couple trips over kinda-rough roads though, I'm convinced it's coming from under the center speaker. I have only 6500~ miles now, but it's usually not too bad, so I might wait until the 10k service.
I would love to get this out of the way myself if it's easy though.. anyone?
Old Dec 29, 2006 | 08:32 AM
lexudv's Avatar
lexudv
Actually it is still very noticable when it is warm. I probably should have rephrased what I said on my earlier post. Trust me I know that if you guys had this noise you would definetely notice it and would be bothered by it. I was just saying that when it is early in the morning it is very loud compared to how it is after you drive for a while.
Who would you guys recommend: Longo or Glendale Lexus. I already have an appt setup for 01/06/07 since I can't be without a car and needed a loaner car. I dont' know why Longo is like that. At Tustin Lexus you just drive up leave your car, if it needs to be there longer than 1 hr they give you a loaner car.
Old Dec 29, 2006 | 08:38 AM
Technique's Avatar
Technique
CL Folding 500,000
Finding rattles are VERY tough sometimes... And with each one you remove, the car becomes quieter, making it easier to hear the other rattles that aren't as loud
Old Dec 29, 2006 | 11:13 AM
sk72's Avatar
sk72
And now my wife things I have sharp ears... should show this posts to her.. n you are absolutely right.. I cannot expect this from a car that is worth over $40K and on top of it ... it's a Lexus..
I had the similar issues with my ES330 .. and they fixed it all... hopefully... it does not come back..
Old Dec 29, 2006 | 11:34 PM
gyung's Avatar
gyung
Like I said, I can live with it... for now... No long road trips yet. Well it's only obvious over some roads... and today I went over the SAME roads and it's not as loud, actually rarely happening. Yeah rattles are a pain in the ***, so I'll wait until the 10k service. Since they charge a buttload of cash anyway, might as well have them find that damn rattle.
Old Dec 30, 2006 | 12:15 AM
ES3's Avatar
ES3
Keep us posted, I've got the same problem. Will tackle it if you also have success.
Old Dec 30, 2006 | 03:09 AM
kiprich's Avatar
kiprich
Hi, some more about noises in the IS... the early IS series made a noise like a stone hitting the car. The noise came from the dashboard.
The solution for this problem is known by the Lexus dealers, the problem seems to be the construction of the heating behind the dashboard. The hard plastic makes loud noises on the metal. The dealer can fix it by putting small rubber pieces between the plastic and metal.
