auto window up
Old Oct 11, 2006 | 10:44 AM
omgitsroy's Avatar
omgitsroy
Default auto window up
i know we can get our windows down from our remote.. but is there anyway to get 'em up... any special configuration?
Old Oct 11, 2006 | 11:01 AM
ISbb's Avatar
ISbb
just press and hold the lock buttom that's it!! enjoy""
Old Oct 11, 2006 | 11:22 AM
NovaIS350's Avatar
NovaIS350
That doesnt do anything...
Old Oct 11, 2006 | 11:52 AM
viettho's Avatar
viettho
That feature is not available in US. I believe this topic was disccussed somewhere in this forum before.
Old Oct 11, 2006 | 01:46 PM
vertcobra9's Avatar
vertcobra9
well since we are on the topic... is there any way to make the windows go down automatically without having to hold the unlock buttom until they are all the way down?
Old Oct 11, 2006 | 01:54 PM
tdrag97's Avatar
tdrag97
if they have it oversea.. there must be something we need to unlock to have it roll up?? right?
Old Oct 11, 2006 | 02:13 PM
waynetech2's Avatar
waynetech2
To Roll The Windows Up: You Have To Pop Off The End Of The Door Handle. Then You Can Use The Master Key, Rotate To The Lock Position For 3 Seconds And They Will Roll Up
Old Oct 11, 2006 | 02:52 PM
viettho's Avatar
viettho
So after doing all of that, press and hold on lock button and it will roll up or we'll have to pop off the end of the door handle to roll up everytime?
Old Oct 11, 2006 | 04:09 PM
omgitsroy's Avatar
omgitsroy
jus doesn't make sense how there's a down..but not up
Old Oct 11, 2006 | 04:28 PM
kensteele's Avatar
kensteele
i'm going to go out on a limb here and say auto up using a remote went a bit too far in terms of liability, at least for Lexus. Although I can't say for sure and of course no one here can say for sure (even though they would like to believe they have the answer)...there might be other car manufacturer's who do this but perhaps Lexus chose not to take on the risk.
I don't call it a safety issue because that leaves too much room for debate. Rather if an accident were to happen, does Lexus want to take on the risk of being liable.
Old Oct 11, 2006 | 05:02 PM
waynetech2's Avatar
waynetech2
NO, TO ROLL THEM up (<- edit.. sorry i meant up)YOU ACTUALLY HAVE TO PUT THE MASTER KEY IN THE DOOR CYLINDER EACH TIme
Old Oct 11, 2006 | 05:42 PM
omgitsroy's Avatar
omgitsroy
to roll them down you don't have to use master key
Old Oct 11, 2006 | 05:46 PM
SParker1tx's Avatar
SParker1tx
Ok Wow...
To roll down the all the windows and sunroof you hold down unlock key on your keyfob until the windows start going down its about 3 to 5 seconds. To get them back up you have to use the key that pops out of the keyfob for 2IS and pop off the plastic part on the door and manually insert the actual key into the hole and turn counter-clockwise which is the way you lock your doors w/ the actual key and hold it for 3 seconds to have the windows roll back up. you CANNOT roll the windows back up by just holding the lock button on the keyfob!
Old Oct 11, 2006 | 07:22 PM
IS_250's Avatar
IS_250
its probably for liability issues like someone said earlier. i know my bro's e46 bmw had the same feature and could only be rolled up with the key in the door or with the window switches in the car.
Old Oct 11, 2006 | 08:06 PM
vertcobra9's Avatar
vertcobra9
Originally Posted by SParker1tx
Ok Wow...
on my car if i hold the unlock key for 3 to 5 seconds and the windowns start rolling down... if i let go of the button at any time while the windowns are rolling down it stops
