Steering wheel will not turn. Not locked
Old Jun 25, 2025 | 11:37 AM
mightymotor's Avatar
mightymotor
2nd gear
Default Steering wheel will not turn. Not locked
Have a 2006 IS250 AWD.
Car starts runs great, battery new, alternator is fine. No lights no codes.
Can not turn the stearing wheel. The wheel lock comes off and can wigle the wheel about an inch either way but will not turn no matter how hard I try.
Any ideas?
Old Jun 25, 2025 | 08:25 PM
Arsenii's Avatar
Arsenii
Hello,
Well, without any background on what predates this issue it would be hard to say anything specific. For now, try taking the U-Joint off of Steering Rack and see if you can turn the Wheel and the Column separately from the Rack, that will tell you where to focus the attention. With that, make sure to leave the Alignment Marks before taking the U-Joint off, such you can install it in the same exact position, and do keep in mind that the Steering Column will still have a Clock Spring attached to it, so do not attempt to turn the Wheel for more than one complete turn for a test.
Hope this helps and best of luck!
holyking
Jul 6, 2025 05:37 AM
gs4lexuus
Performance
Jul 2, 2025 06:31 AM
Sep 1, 2022 02:46 PM
KingR413
Jul 18, 2021 07:10 AM
pmarr
Jan 3, 2016 07:53 AM
