IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
In a Jam.. Need help Please!
Old Dec 25, 2012 | 06:17 PM
IStonyG's Avatar
IStonyG
Default In a Jam.. Need help Please!
Hi newbi here. I did a sparks plug change a couple days ago and everything came out well so i thought. Today i was doing some daily driving when all of a sudden the check engine light, trac off light, and vsc light came on. I tried to do some research and thought it could have been the gas lid was not on right so after checking everything seemed okay but the light still came on. Can anyone give some input on what it could be? I have a 2004 IS300 with 138k miles.
Thanks[
Old Dec 25, 2012 | 07:27 PM
2broke2mod's Avatar
2broke2mod
Best thing would be to run the codes. Maybe a misfire
Old Jan 3, 2013 | 05:57 AM
cashed350's Avatar
cashed350
if those lights are on and the TRAC light on the dash "flashes" while running, its a random misfire code. you will have to check coils and oxygen sensors.
Old Jan 4, 2013 | 12:58 PM
lookalike's Avatar
lookalike
like 2boke2mod says you need to check the OBD codes. it could just be a loose wire, maybe you forgot to plug something in?
For some reason Lexus decided that anytime the check engine light turns on for any reason the TRAC light will flash constantly. Doesn't necessarily mean you have a misfire. These cars are known to have issues with oxygen sensor so thats my main suspect, however pull the code.
Just an idea, theres tons of guys on craigslist that will read your code for $20 or less so its worth at least spending the $20 vs wasting countless hours trying to troubleshoot. Or you can find the manual method of checking the code on my.is forum.
Old Jan 9, 2013 | 08:42 AM
bacon22's Avatar
bacon22
maybe a vacuum hose slipped off and poped the alarm...
Old Jan 9, 2013 | 01:19 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
Not completely true...
If the trac light is flashing, it is because there is an ignition control or throttle control failure - things that would prevent the traction control system from working properly... It does not flash for any and every code, for sure, the easiest way to get it to flash is multiple random misfires, ask me how I know... (the factory ECU doesn't have the same timing sequence as an aftermarket computer, like the AEM I have, so it thinks it is misfiring terribly under any sort of real load...)
Old Jan 15, 2013 | 06:38 PM
truviethug's Avatar
truviethug
autozone reads codes for free
Old Jan 16, 2013 | 09:40 PM
edgy's Avatar
edgy
inexpensive code readers are available online or at harbor freight for less than 30 bux.... get one...
Old Jan 17, 2013 | 06:05 AM
selmerguy's Avatar
selmerguy
My Trac light was flashing for the B2S2 heater code....
To the OP, go to auto zone or another parts stor and they will read it for free. That is a start. Then do some research on that specific code on here and you will most likely fix it.
Old Jan 19, 2013 | 06:49 PM
2jzcrazy's Avatar
2jzcrazy
Thanks[
Go to autozone for free diagnostic check u will get the codes and what it mean. And it is FREE
aachowhan
Feb 5, 2017 03:48 PM
windom619
Sep 30, 2009 08:36 PM
relax221
Jul 24, 2009 06:59 AM
garcia5280
Apr 10, 2009 10:43 AM
06i
Jan 13, 2008 07:23 PM
