IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Help: How do i remove double sided tape
Old Mar 11, 2011 | 12:41 PM
Grazy's Avatar
Grazy
Default Help: How do i remove double sided tape
i have a rear spoiler that im parting out. I used double sided tape on the rear spoiler. It's holding quite strong. i cant just pull it out because the spoiler might bend or crack. Anyone got a good way to take it out safetly?
Old Mar 11, 2011 | 12:45 PM
4pointslow's Avatar
4pointslow
slide a razor blade under it as you pull gently. Careful not to gouge the paint. Razors can get hooked onto edges so friggin easy.
Old Mar 11, 2011 | 12:46 PM
Shadowen's Avatar
Shadowen
Floss like you would use for your teeth and run it under the spoiler. Also a bit of windex helps and shouldn't harm the paint.
Old Mar 11, 2011 | 05:37 PM
plus1choi's Avatar
plus1choi
Spray from 3M adhesive remover, that should help quite a bit
Old Mar 14, 2011 | 11:45 PM
1sikkis300's Avatar
1sikkis300
goo gone works good too !!!!
Old Mar 14, 2011 | 11:48 PM
Bigrahizzl's Avatar
Bigrahizzl
wd-40 works too but dont leave on paint for too long
Old Mar 15, 2011 | 11:55 AM
llllllllll's Avatar
llllllllll
These are best suggestions..
Don't "floss" or use razorblades unless you don't care about your paint...
Old Mar 15, 2011 | 01:04 PM
baadhabit's Avatar
baadhabit
to remove the spoiler you'll first need to soften the glue/tape with a heat gun or hairdryer. once the glue is soft use dental floss in between the wing and the trunk to separate the tape. then once the wing is off use something like go gone or wd40 to get any residue glue off the trunk.
do not use a razor blade.
Old Mar 15, 2011 | 01:05 PM
baadhabit's Avatar
baadhabit
dental floss wont scratch the paint. i went through this same process to remove the oem emblems.
Old Mar 16, 2011 | 04:04 PM
plus1choi's Avatar
plus1choi
forgot about heating it up first. that will really help a lot! heat gun if you have, if not blow dryer will get the job done. for sure NO on the razor blade. who suggested that?!
Old Mar 16, 2011 | 10:13 PM
Kingpin's Avatar
Kingpin
Floss and Goo ..
sens
Sep 25, 2013 12:53 PM
EthanV
Apr 13, 2009 09:42 PM
PureZ
Nov 8, 2007 11:18 AM
JDarty6173
Automotive Care & Detailing
Sep 20, 2007 04:10 AM
Lettuce
Apr 15, 2004 05:51 PM
