Removing doublesided tape?
Is there any way to remove a spoiler installed by double sided tape? My spoiler has a scratch so I want to get it repainted. Its fiberglass and im hesitant to put too much force on it when removing. Any suggestions?
I have used the hot So Cal SUN several times and it worked like a charm..
Heat Gun is a not a good idea.. it can & will burn the paint if mis-used..
A blow dryer is much safer... Try to do this on a warm sunny day.. not sure if there are any coming up in NJ..
3M Spray Adhesive remover should help in cleaning up the trunk area of any residue after the lip is removed..
Again, when used carefully..
Jz
Jz
WeisISF
Sep 29, 2012 07:09 AM
lexus-is2
Sep 14, 2011 01:40 AM
Bigrahizzl
Feb 26, 2011 02:02 PM
