Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
New vs Used Brake Actuator
Old Nov 6, 2021 | 12:01 PM
colenzae's Avatar
colenzae
Default New vs Used Brake Actuator
I own a 2006 Highlander Hybrid and need to replace the brake actuator. I am weary about replacing with a used one because the originals were failing prematurely. I also would rather not put a brand new one into a 15 year old vehicle with 235,000 miles on it. I am assuming the new actuators have a design change that fixes whatever issue the originals had that made them fail prematurely. Is there anyway to tell if the used ones incorporate the new design or do I have to buy a new one to be sure??
Old Nov 6, 2021 | 12:35 PM
The updated unit is 44050-48191 if you see 44050-48190 I would assume that is not the updated part. There may have been a running change, but 44050-48191 will definitely be the revised actuator. My memory if fuzzy, think there was a warranty extension where Toyota would replace defective units but there was never a recall.
Every single used part is going to be 44050-48190 because the only way you'll see the revised part as used is if the donor car had the repair done, which wasn't very many.
td;dr don't think there is any way to know if 44050-48190 is an updated version if that happened at all.
Old Nov 6, 2021 | 01:35 PM
iMSQ's Avatar
iMSQ
04003-45148 is OK since it was installed as a warranty replacement (# from tsb)
44050-48191 is OK since it was installed as a non-warranty replacement (when the warranty has expired)
Old Nov 6, 2021 | 01:50 PM
colenzae's Avatar
colenzae
Thanks!!! LeX2K and iMSQ...
Old Nov 6, 2021 | 02:52 PM
Why are two different part numbers still available?
Old Nov 6, 2021 | 07:55 PM
iMSQ's Avatar
iMSQ
dealer could order the first one for warranty replacement only...
Old Oct 19, 2022 | 01:47 PM
jooksing82's Avatar
jooksing82
Both Parts available here https://parts.elmhursttoyota.com/ Seems to be run by a 3rd party site called revolutionparts as several dealers in different sates have similar site. About to pull the trigger for one of them and see if i can do local pickup. Time of writing both part cost $1,177.33.
Old Jul 9, 2023 | 09:34 AM
Deez20's Avatar
Deez20
1st Gear
Default Same boat
So is it safe to use the new model?
Old May 16, 2026 | 07:32 AM
binthere222's Avatar
binthere222
7th Gear
Default NEW ABS supersession part
I just got off the phone with a Lexus parts department and they swear that there is a new superseding part number. 04003-45148. For the 2nd gen.
caverman
Sep 18, 2021 08:13 PM
Richardgil
Jun 20, 2019 03:18 PM
cycle22
May 20, 2019 10:24 PM
Brucemac
Jun 22, 2018 09:30 AM
subzero32
Suspension and Brakes
Jul 19, 2011 06:32 PM
