07 LS460L Brake Issues
Old May 18, 2019 | 12:43 PM
cycle22's Avatar
cycle22
Default 07 LS460L Brake Issues
Just installed new OEM brake actuator and brake booster... The technician tells me that the brake actuator is constantly on/running while the car is sitting still.. Also says the yaw sensor outputting voltage almost as if the car is in a spin or out of control.. Anybody ever experience anything like this with your LS460???
Old May 18, 2019 | 02:55 PM
jdanielca's Avatar
jdanielca
Never read of this on here did it have a problem before you installed? Who installed it? You? I’m guessing something wasn’t done right.
Old May 18, 2019 | 03:30 PM
yyymmm31's Avatar
yyymmm31
It looks that there is air or a leak in your brake system. Ask your technician if he/she used Techstream to bleed the brake system per Lexus procedure for replacing brake actuator. Often, small indy shops don't follow Lexus repair procedure to replace brake actuator and pump, resulting in air in the brake system. Then, the brake actuator constantly attempts to adjust the brake fluid pressure (the long clinking noise from the actuator). You could ask your technician to follow Lexus repair procedure to do the "replace brake actuator" bleeding procedure. Most likely, the problem will be fixed. Good luck.
Old May 20, 2019 | 10:24 PM
cycle22's Avatar
cycle22
Installed by a factory trained technician.. he use to work at the Lexus dealership that we purchased the new parts from..
I will run this by him and ask him about the bleed procedure..I do recall him saying that the brake bleeding process was difficult and that it is a timed procedure for each step etc.. thanks for the insight!
UZ214
Nov 12, 2017 09:49 AM
Wallander
RX - 3rd Gen (2010-2015)
Jan 20, 2017 10:11 AM
2v1g
Dec 2, 2016 06:40 AM
IStreefidy
Suspension and Brakes
Nov 14, 2006 04:37 AM
