Are brake actuator issues resolved in 2013+?
Old Sep 14, 2021 | 08:52 PM
caverman's Avatar
caverman
Default Are brake actuator issues resolved in 2013+?
I'm looking at some 2013+ LS460 and have been trying to do some searching on what issues they may have and the brake actuator issue popped up. I thought I heard that on 2013+ that the brake actuator issues had been resolved. Is that true? Has anyone heard of any 2013+ actually having issues and if so does it seem to be few and far between or just as common as the '07 - '12 models?
Old Sep 15, 2021 | 02:41 AM
TriC's Avatar
TriC
It still crops up on the newer models, but seems to be less frequent.
Old Sep 15, 2021 | 04:39 AM
Anfanger's Avatar
Anfanger
The brake actuator issue exists because people do not do maintenance when it needs to be done. If you let 2013+ run on old brake fluid, the actuator will go out the same way it does on the older model.
The reason 2013+ seems to have less issues with the actuator is because Lexus started recommending brake fluid.
Old Sep 15, 2021 | 07:12 AM
TriC's Avatar
TriC
While this may be generally true, Anfanger, I know of 2 late models (including one that was owned by a member here) where the actuator failed at less than 20,000 miles and 3 years of age.
Old Sep 15, 2021 | 07:19 AM
Anfanger's Avatar
Anfanger
Wow, I did not know that! Thank you for letting me know! I guess, the issue remains then.
Old Sep 15, 2021 | 05:15 PM
Brake Actuator went out on my LS at about 15k miles...so its definitely still possible.
Old Sep 16, 2021 | 08:14 PM
Boykie's Avatar
Boykie
In short - no. But.... Ugh if only I'm allowed to speak openly on this heavily NDE'd topic. All I can say - if yours goes out right now (xmas tree of lights, the usual) and you go to a decent dealer and push for replacement, there IS a chance you will get an.....ted unit. It will not look different AT ALL. But it will be AN ......nit. Wink wink. If you, however decide to use a parts catalog(epc/microcat) the part it will show you will not be an ......ed unit.
U
Old Sep 17, 2021 | 02:58 AM
lexus13dan's Avatar
lexus13dan
Pretty rare in 13 plus 460s
Old Sep 17, 2021 | 04:07 AM
Anfanger's Avatar
Anfanger
Do you know if the replacement part was the same part number or it superseded by a new part?
Old Sep 17, 2021 | 06:55 AM
Boykie's Avatar
Boykie
Toy won't tell you/show documents. It's a big snafu for the company (as e.g. with cam actuators), they don't want extra attention.
Old Sep 17, 2021 | 06:59 AM
Anfanger's Avatar
Anfanger
That is BS. I never had issues with local Toyota/Lexus dealers showing parts numbers and any involved paperwork.
Old Sep 17, 2021 | 07:00 AM
Boykie's Avatar
Boykie
Not in this case. There's an internal document being circulated, that forbids making client aware. I have this document. If I share it - I go to jail.
Old Sep 17, 2021 | 07:06 AM
Anfanger's Avatar
Anfanger
I have a right to know what is being done my property. I just do not believe you.
The superseded part number for the actuator is (LS460 07-17) - 44050-50110.
Old Sep 17, 2021 | 07:21 AM
Same part. My 2017 LS460L was one of the last 460s made.
Old Sep 17, 2021 | 07:43 AM
Boykie's Avatar
Boykie
Wrong. Wrong. Enjoy ignorance. Bye.
