Hybrid Technology Unique topics related to the GS450H model hybrid drivetrain and other features/options found only on the GS450H. Please use the main 3GS forum for discussion about shared components with other third generation GS models.
GS450h- Noise from under the car when the cold engine started status...
Old Aug 2, 2023 | 01:32 AM
Lwerewolf's Avatar
Lwerewolf
Do a compression test, a smoke test (intake / exhaust leaks) and a coolant pressure test beforehand just in case, before you go and chase ghosts. AFAIK all 450h's do this, although there is indeed that TSB for the low pressure injectors on the 4th gen (or was it only for the RX 450h).
Old Dec 21, 2024 | 02:20 AM
lemony5553's Avatar
lemony5553
5th Gear
Is the car shaking while it's doing that? "Minor misfire"-like? If you look at the diff guibo bushing, is the driveshaft moving about (when the engine is idling)?
hey there, do you mind if I ask if this guibo failing could cause the transmission to jerk on, start up, and the engine to knock when the ICE engages from electric?
I am trying to fault find my issue. It may be that there is more than one thing going wrong.
Cheers
CRowe14
Nov 19, 2019 12:49 PM
mel's-gs
Nov 25, 2011 08:24 PM
kyo7878
Hybrid Technology
Feb 15, 2011 07:57 AM
sjgIS350
May 5, 2008 10:51 AM
skk440
Sep 21, 2007 11:08 PM
