Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Towing an rx400h on a dolly
Old 04-17-17, 08:28 AM
Allen6767
Allen6767's Avatar
Default Towing an rx400h on a dolly
Folks, trying to find the correct way to tow a 2008 rx400h on a tow dolly from ACME that is fixed axle & no moving tire plates like other dollies. Owners manual is no help. I have found if you leave the key in the ignition after turning it to accessory & back the wheel stays unlocked. This is what I need to to do for this type of dolly. I just want to make sure it stays in the unlocked position, but not drain the battery.
FPLexus (05-08-20)
Old 04-17-17, 03:30 PM
tbm5690
tbm5690's Avatar
AWD I presume? If so, the only option for towing is to have all 4 wheels off the ground, period. If what you are describing has only the fronts in the air and the rears dragging behind, you will need to find another solution.
Old 04-17-17, 03:37 PM
RedGemini
RedGemini's Avatar
Not quite the only option...
There is another option, but you'll have to play it smart and careful. I'm not sure if the prop shafts are balanced on these, so some of this might not apply.
Use a paint pen to mark the prop shaft and where it connects on both ends (to align the marks for reinstall). Unbolt and remove the prop shaft going to the rear differential. Unlike the front wheels, the rears don't require the engine/transmission running to circulate fluid.
This is assuming it's a physical AWD system for the rear, and not electric motors. I'm not sure about the 400h.
FPLexus (05-08-20)
Old 04-17-17, 07:40 PM
BlackLexRX
BlackLexRX's Avatar
This for awd.
And RedGemini is correct for non hybrids-unhook drive shaft, but hybrid RXs have electric motors and traction batteries hooked up to rear axles on awd's so if you have awd, probably need to tow with all wheels off ground.
FPLexus (05-08-20)
Old 04-18-17, 08:18 AM
Allen6767
Allen6767's Avatar
Default 2 wheel drive/ front wheel drive only
Thanks should of clarified to start. 2 wheel drive/ front wheel drive only
FPLexus (05-08-20)
Old 04-18-17, 11:52 AM
BlackLexRX
BlackLexRX's Avatar
Should be fine to tow then with front wheels off ground. Key in acc position so column stays unlocked. For good measure, I'd look under rear end just to be totally sure there's nothing but axles, no hybrid stuff attached. I've seen towed vehicles where their turn signals and brake light also work in tandem with lead vehicle which sounds like the safest way to go so probably look into that.
FPLexus (05-08-20)
Old 04-18-17, 11:54 AM
BlackLexRX
BlackLexRX's Avatar
Might be a good idea to search or start a thread in the hybrid forum. I'm just wondering about how your brakes, etc, are hooked up to the traction battery.
FPLexus (05-08-20)
Old 04-22-17, 01:21 PM
Allen6767
Allen6767's Avatar
Ok folks, did a test run with it in ACC mode & with the key still in but turned off. Steering did not lock up & everything appeared ok except. Bothe times after restarting & taking it off the dolly the VSC light came on. After I drive it down the block it cleared both times.
FPLexus (05-08-20)
Old 04-22-17, 01:25 PM
Allen6767
Allen6767's Avatar
Default Properly towing Lexus Rx400h on ACME tow Dolly
Will this hurt anything?
FPLexus (05-08-20)
Old 04-22-17, 01:28 PM
BlackLexRX
BlackLexRX's Avatar
Could be nothing, but that would be a deal breaker for me.
FPLexus (05-08-20)
Old 03-21-18, 02:21 PM
jooksing82
jooksing82's Avatar
I found this on AAA
https://aaacampus.aaa.biz/wp-content...vice_guide.pdf
FPLexus (05-08-20)
japanbran
06-21-21 08:10 AM
Salespr0
04-14-17 10:30 AM
sapd911
ES - 6th Gen (2013-2018)
09-22-14 11:38 AM
skullkandy
08-28-12 08:10 AM
Quick Reply: Towing an rx400h on a dolly
