Keyless Remotes
Old Apr 12, 2017 | 05:11 PM
Salespr0's Avatar
Salespr0
Default Keyless Remotes
Does the push button keyless remote take batteries if none of the buttons operate?
Old Apr 12, 2017 | 11:15 PM
rebpdx's Avatar
rebpdx
I believe so, not sure if there's any programming required after replacing the battery. I did just see the instructions in the manual last night while on the hunt for homelink stuff so I can help you with getting to the battery.
Pull out the emergency key, by pressing the button next to the key ring. That will expose a slot in the corner. Put the end of the key in the corner slot and twist. It should help pop the back off from the rest of the case. You'll find a CR1632 in there, I'd recommend doing this over a table or bed because the parts can separate, board, buttons, case, etc.
Old Apr 13, 2017 | 02:55 AM
Bichon's Avatar
Bichon
No programming is required, just pop the case open as rebpdx described, and change the battery.
Old Apr 13, 2017 | 01:02 PM
mandyfig's Avatar
mandyfig
The manual states it so, too.
Old Apr 14, 2017 | 10:30 AM
HankMoody's Avatar
HankMoody
No they just need to be rubbed on the carpet or your leg, to create some static electricity.
Emmerz
Mar 30, 2017 06:35 AM
ChitChat
RX - 3rd Gen (2010-2015)
Feb 9, 2015 11:56 AM
gtstcactus
Feb 8, 2014 08:00 PM
GFC350
Oct 22, 2010 11:57 AM
gstonerock
Feb 15, 2009 12:57 PM
