Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Really low MPG?
Old Feb 18, 2009 | 07:38 AM
vmcgarve's Avatar
vmcgarve
Default Really low MPG?
I have never gotten the posted mileage on my 2007 rx400h -- I have peaked at between 23-24 MPG. Recently my MPG has plummted and I am now getting 16-18MPG. The dealer says everything is fine. I have not changed my driving habits and am even more conscientious about "gliding," etc. Anyone else have this experience? Suggestions?
Old Feb 18, 2009 | 07:43 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
This probably wouldn't account for as big a change as you note but can make a significant difference.... when is the last time you checked the tire pressure in all your tires?
Have you changed gas brands / grades / stations?
Just starting with the simple stuff
Old Feb 18, 2009 | 07:45 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
A lot of accelerants are being used in todays gas, politics as usual IMO.
Old Feb 18, 2009 | 07:46 AM
vmcgarve's Avatar
vmcgarve
No changes. Same regular station, gas. Have checked the tires a lot (low pressure indicator kept going off -- turned out to be the spare). Just in to dealer for 15,000 service. No significant change since then.
Old Feb 18, 2009 | 09:40 AM
jrobe's Avatar
jrobe
What do you see on your energy monitor when you are only getting 16-18 mpg? It must never run just on the battery/electric motors to get mileage like that. In fact, the Rx350 gets better mileage than that.
Something is clearly wrong with your vehicle. It would be impossible for me to get mileage that low, even now in the winter. I have even towed my 2000lb boat on trips of 300 miles + and still gotten 18-20 mpg.
Old Feb 18, 2009 | 10:05 AM
Lexmex's Avatar
Lexmex
Welcome to the Club.
What brand of gas/octane are you using?
Old Feb 18, 2009 | 10:48 AM
NeoNz's Avatar
NeoNz
thats not good, are u taking alot of 5 min trips? in start up around town i only get 10 mpg for the first 5 mins sometimes or even less depending on where u are
Old Feb 18, 2009 | 11:45 AM
GQD_GS4's Avatar
GQD_GS4
lots of quick trips will kill MPG because the motor stays on to warm the engine.
also, using your heater will keep the engine running at stops to keep the heat going.
Old Feb 18, 2009 | 02:17 PM
Joeb427's Avatar
Joeb427
Winter blend gas and warm ups?
Old Feb 18, 2009 | 02:36 PM
herbvdh's Avatar
herbvdh
The biggest culprit right now is the weather with it being cold out the gas engine must run more to warm up thereby decreasing your gas milage. I have dropped about 10% to 15% decrease in my gas milage. As outdoor temperature goes down so does your Miles Per Gallon.
Old Feb 18, 2009 | 03:01 PM
oldcajun's Avatar
oldcajun
Exactly right! The only source for cabin heat is the ICE so when it is cold out, it runs to keep the cabin warm. For short trips, it will also run to heat the catalytic converter. This is one of the real limitations with the hybrid system and one of the as yet unsolved issues for plug-in electric cars. The real "sweet spot" for hybrid operation is the crowded freeways of Southern California. The least favorable operation would be open freeways in some place like North Dakota with little traffic, no stop and go driving, and cold outside temperatures.
The new 450h has some modifications to the ICE to improve the situation.
Steve
Old Feb 19, 2009 | 08:48 AM
jrobe's Avatar
jrobe
I live in northern Wisconsin (about as cold as you can get in the US) and I have my heater and seat heaters on almost all of the time. I still average over 24 mpg in the winter. I took a 500 mile trip last weekend on the freeway (72 mph) with the heater on and averaged over 25 mpg (regular gas).
If he is getting 16-18 mpg, something is wrong unless he is making 5 minute trips only in Nome, Alaska.
Old Mar 6, 2010 | 09:08 PM
06WTRX400H's Avatar
06WTRX400H
never tried this.. I don't think anyone suggested it either
http://us.lexusownersclub.com/forums...30&hl=learning
zmwu
14
May 5, 2017 07:20 AM
robo02
GX - 1st Gen (2003-2009)
15
Oct 25, 2012 08:47 AM
LBCDan
Jul 9, 2010 07:48 PM
LansingLx
Jan 13, 2010 07:34 AM
isam250
Sep 27, 2006 06:48 PM
