Hybrid Technology Unique topics related to the 2023 up RX model hybrid drivetrain and other features/options found only on the hybrid models. Please use the main forum for discussion about shared components with other fifth generation RX models.
Distance to Empty - Not even close
Old Mar 25, 2024 | 08:14 AM
  #211
Nasahos's Avatar
Nasahos
All 8 of my RX’s would take about 4 gallons when said 0 miles DTE.
Old Mar 25, 2024 | 11:07 AM
  #212
scdroptop's Avatar
scdroptop
On my 2023 Rx500h I'm only getting 18-19 mixed city/hwy driving. Mixed Normal to Sport modes. Can only fill up the tank 12-13 gallons when it's supposed to be filled up according to the dashboard, if I push the limits and drive till zero miles to empty and below, I can squeeze 14 gallons in the supposedly 17.3 gallon tank. The Rx350's I get as a loaner vehicle get way better MPG even the gas models versus my 500h. Anyone else care to chime in on the 500h MPG/fuel tank capacity?
Old Mar 25, 2024 | 11:12 AM
  #213
mikemu30's Avatar
mikemu30
There's another thread about fuel capacity. It appears they have a very conservative reserve with several gallons of headroom when it comes to calculating miles to empty.
Old Mar 25, 2024 | 11:17 AM
  #214
WellsB's Avatar
WellsB
There is a RX500h fuel economy thread;
https://www.clublexus.com/forums/hyb...x500h-mpg.html
Old Apr 12, 2024 | 12:34 PM
  #215
JTCA's Avatar
JTCA
7th Gear
Default Gas Tank and Fuel Reserve
The 5th gen RX has a 17.2-gallon gas tank per manufacturer specs. However, I could hardly put 13 gallon of gasoline in when the fuel gauge showed empty. I understand the need for car manufacturers to be conservative and maintain a "reserve" of fuel, but 4 gallons seem to be excessive, especially considering the MPG of the hybrid RX's. We are talking about at least 120 miles of driving range after the gas tank is supposedly empty. This seems overly conservative and in fact mis-leading. This is akin to the speedometer showing 75 mph when you are actually going 55 mph, just to make sure that you are not speeding. We want and need our instrument panel showing accurate information so that we can make correctly informed decisions.
Old Apr 12, 2024 | 01:19 PM
  #216
Urlik's Avatar
Urlik
Your post will get moved here by the mods: https://www.clublexus.com/forums/hyb...ven-close.html
Old May 2, 2024 | 12:39 PM
  #217
patricias's Avatar
patricias
1st Gear
Default Fuel tank might be damaged
We have been noticing that when we fill the tank, it takes a much smaller amount of fuel than expected. So today, showing only approximately 1/8 tank, and 53 miles remaining, it only took 9.6 gallons. Even after trying to add more (which we never typically do), it only took .1 more fuel. Wondering if we might have a partially collapsed tank. Had this happen years ago in a brand new Volvo that had the same symptom.
FYI: Consistently showing we get 35.1-35.5 mpg.- but don't think that information helps (?)
Old May 14, 2024 | 01:28 PM
  #218
jhall81's Avatar
jhall81
1st Gear
Default RX 350h Fuel Capacity
Has anyone had issues filling their tank to capacity ? I’ve had my RX for 8 months and still can not get more than 14 gallons in it. The fuel pump cuts off at 11 or 12 and then I have to force the gas in to get to 14. That’s if I’m near empty with the light on. I had 50miles left and the pump stopped at 10.8. Dealer says no other issues like this have been reported. Thoughts ? I’m getting 38.5 mpg , but would like to be able to get closer to a 17 gallon tank .
Old May 14, 2024 | 01:44 PM
  #219
chuckNX's Avatar
chuckNX
From what I can tell, fuel tank is a little over 17 gallons in size.
There is a 3-4 gallon reserve when the fuel gauge reads empty.
I have not tested the reserve amount. I assume there is 3-4 gallons left when on empty. Each time I fill up on empty, I put in around 12-14 gallons. Kinda sucks to have 25% of your tank in a reserve status.
Old May 15, 2024 | 06:12 AM
  #220
Carbuff2's Avatar
Carbuff2
Originally Posted by jhall81
Has anyone had issues filling their tank to capacity ? I’ve had my RX for 8 months and still can not get more than 14 gallons in it. The fuel pump cuts off at 11 or 12 and then I have to force the gas in to get to 14.[...]Dealer says no other issues like this have been reported. .
@jhall81
First: Don't try to FORCE extra fuel into the tank, you may damage the evaporative control system. It is made to contain VAPOR, not liquid FUEL.
Next: If you have read the entirety of this Topic you will see that what you experience (showing empty with 5+ gallons remaining) is almost universal. So the dealer must be wearing ear plugs, LOL. The official story is that the extra gasoline is necessary to protect the hybrid system.
If you want to complain to anybody, tell the dealer that you want to confer with Lexus Corporate, then DO IT. Not sure if they can/will do anything, but make your voice heard to someone who can do something...
Old May 25, 2024 | 11:34 AM
  #221
Erix350h's Avatar
Erix350h
1st Gear
Default Know issues
My dealership told me it was a know issue and to have it documented. I feel it is a programming problem with the gauge, possibly due to the shape.
Old Jun 7, 2024 | 11:57 AM
  #222
JamieGunner's Avatar
JamieGunner
2nd gear
Default Dte
I have same issue with my new Rx 350h. I fill up once a month after driving in 'normal' mode. I tend to drive until DTE is at close to zero - because there is an apparent ample reserve. I try to put a consistent 14 gal in the tank. It might click off from Costco hoses between 13 - 13.5 gal, then I round off to 14 gal (don't think I'm over filling as I can keep going if I wanted). Anyways, wanted to share my story. After filling, DTE is approx 550 miles and I pretty much hit that.
Old Jun 7, 2024 | 12:06 PM
  #223
Lexus-SSA's Avatar
Lexus-SSA
I tried the same thing and always got only about 505 miles to empty. I am now visiting Portland and the pump nozzle is a little smaller even on a Super Unleaded and for the first time got 530 miles to empty after filling. I did not top off. Maybe the flow rate is much slower than in California. Bottom line is that 5 gal reserve does not make sense.
Old Jun 7, 2024 | 12:14 PM
  #224
JamieGunner
2nd gear
As said in this discussion, DTE is based off historical achieved mileage. How many gal are you putting in before getting the DTE = 505? How many gal did you put in to get the DTE = 530?
Old Jun 20, 2024 | 09:53 AM
  #225
Eagleboy99's Avatar
Eagleboy99
Filled up today after 890 kms on a full tank. Probably 60/40 hwy/city. Averaged 5.8 l/100 or about 48 Imp. MPG/40.5 US MPG. I could only get 51.7 l into the tank. That is a LOT of reserve on a 65 liter tank! But I sure cannot complain about the MPG.
