Hybrid Technology Unique topics related to the 2023 up RX model hybrid drivetrain and other features/options found only on the hybrid models. Please use the main forum for discussion about shared components with other fifth generation RX models.
Distance to Empty - Not even close
Old Dec 4, 2023 | 01:47 AM
  #151
mathjak107's Avatar
mathjak107
i agree .
we know there is an issue so blindly trying to work around it can lead to expensive trouble .
just work within the parameters we have and put in less gas
Old Dec 4, 2023 | 04:32 AM
  #152
Carbuff2's Avatar
Carbuff2
I'd love to see a explanation from a Lexus/Toyota engineer if they actually feel that such a large reserve is needed.
If not, a video on "How to Remove the fuel tank sending unit, and bend the sender's float for more accurate readings"
Back in the 1990s, an acquaintance was a Toyota engineer. If he were still alive, I'd get the answer, quick.
Old Dec 4, 2023 | 07:01 AM
  #153
NickL's Avatar
NickL
This is enough for a dealbreaker for me. I’ll wait for 2025. 😂
Even though it’s 2 gals, the vehicle is doing 25-30MPG. That 50 more miles that I could’ve avoided the gas station.
The whole point for me going to HEV or PHEV is the longer range from higher mpg. But if the sensor kicks on at 12gal on a 17gal tank, that is pretty lame. I thought this is only a thing with small hybrid vehicle like a Corolla where the tank is tiny even though it has good mpg.
These RX are carrying a 17Gal tank but you have to pump at 12. So is it carrying 5 gallons of extra fuel all the time in a 17Gal tank. Or only 15 gal of fuel can be dumped into a 17Gal tank?
Old Dec 13, 2023 | 01:07 AM
  #154
Seulbee77's Avatar
Seulbee77
6th Gear
Originally Posted by maormaor
Hi All,
I just bought a 2023 lexus RX350H recently. Manual says it has a 17.2-gallon fuel tank. So far I have refilled the tank twice (with ~20 miles left each time before the refill) but each time it only took ~12 gallons. For each ~12 gallon I could drive 380-400 miles. I am just curious why the gas tank only holds 12 gallons for my car whereas it should hold 17?
Anyone has a clue?
Thanks.
I had the same problem! I didn’t want to only refuel at 12 gallons every time. I took it to the dealer with about 20 miles left and told them I want to be able to drive the 17 gallons the spec states. They refueled the car and of course it stopped at 11.5 gallons. Then the manager kept pumping while the gas pump kept stopping, forcing extra in. It finally overflowed at 15.5 gallons! They said there is couple gallons after fuel shows empty, so there is the total 17 gallons. I now fill my gas until it stops at around 12 gallons and then keep pumping it additional 2 gallons so I don’t have to refuel as often. I drive at least 500 miles a week driving my kids all over town for their activity on local roads. My best record is 620 miles at 40mpg when dealer filled it to 15.5 gallons. Next best is 582 miles with 14 gallons, yielding 41.5mpg. This is my first hybrid and I’m noticing driving style will impact that mpg significantly and have been driving gently to get best mileage.
Old Dec 13, 2023 | 05:00 AM
  #155
ggebhardt's Avatar
ggebhardt
Consider for 350h to be typical. They all have the same problem.
Old Dec 13, 2023 | 06:24 AM
  #156
jahnjva's Avatar
jahnjva
Seulbee77,
You are going to ruin your evap canister if you keep forcing in fuel and then it's going to cost you $$$$. 12 gallons is the norm for the RX 350. It's a Lexus glitch but they refuse to acknowledge it. Put the 12 gallons in and stop when the pump clicks off. They should be charged with false advertising.(619 miles Total Range 17.2 x 36mpg). The dealer was an idiot to overfill the car, he should know better.
Old Dec 13, 2023 | 06:28 AM
  #157
Urlik's Avatar
Urlik
Originally Posted by jahnjva
Seulbee77,
I agree. If it bothers you others have reported driving the car around the block and then hitting the pump again and the tank will fill the rest normally without backing up in the neck, clicking the pump handle off, and possibley filling the evap canister with gass.
Old Dec 15, 2023 | 09:42 PM
  #158
Eagleboy99's Avatar
Eagleboy99
Mine took 53l/14 US gallons today. The car predicts almost 800 kms. Since the tank is 63 liters, and consumption is about 6-7l/100, that means I should theoretically get almost 1000 kms on a tank. I am sure if I drove conservatively (HA! Like that will happen!), 1000 kms (621 miles) on a tank is easily accomplished. But I can live wiith 850-900 kms on a tank.
Old Dec 20, 2023 | 01:55 PM
  #159
jahnjva's Avatar
jahnjva
Filled up 350h today. It took 14.5 gallons on 1st pump click off. I had driven for a while after the light went on . Usually I put around 12-13 gallons in when the light goes on. I drove 495 miles so 34.1mpg. Car had calculated 35.9mpg. I think cold weather plus wife likes to idle to keep warm dropped the average. I usually get 36+mpg. So 17.2 - 14.5= 2.7 gallons left in the tank. I wonder how many more miles I could have gone before I ran out of gas? I had a 1.25gallon container as a backup but didn't use it. I'm not sure if 1.25gal would have worked if I had driven farther and the car dropped below 2.6 gallons and I tried restarting the car. If you read the note below it says that if the car runs out of fuel, you should add at least 2.6 gallons to make the light go out. Other wise the hybrid system may not start. Will the car keep running till the 2.7gallons are used up? Will it just not restart the hybrid system if it still has gas in the tank but below a certain thresh hold? (2.6gal)
Running out of fuel
When the vehicle has run out of fuel and the
hybrid system cannot be started, refuel the
vehicle with at least enough gasoline to
make the low fuel level warning light
(P.519) go off. If there is only a small
amount of fuel, the hybrid system may not
be able to start. (The standard amount of
fuel is about 2.6 gal. [9.8 L, 2.2 Imp. gal.],
when the vehicle is on a level surface. This
value may vary when the vehicle is on a
slope. Add extra fuel when the vehicle is
inclined.)
Old Dec 22, 2023 | 05:54 PM
  #160
DavidTK's Avatar
DavidTK
9th Gear
Running out of fuel
inclined.)
After waiting for 6 weeks, I finally got my Iridium 2024 rx 350H. Love the car but was concerned about if I would have the same problem with the gas gauge and unfortunately I do. My gas light came on with 23 DTE. The last fuel marker disappeared after the "refuel" warning showed. This was my first time refueling and I asked my sales person do they top off the fuel when they sale the car and she said yes. When I filled it up, it only took 14 gallons. I know that the 37MPG is an estimate and was done under perfect conditions. (drive at 55, no heat or air, flat road etc). I'm thinking that if there is 2.7 gallons left when the gas light comes on, then that's about at least 80 miles that I can still use. But that scares me. I only got 380 on the tank. Since it's my first tank, I knew I wasn't going to get optimal mileage. I'm already averaging 33 MPG with premium gas (the dealer puts in regular). But I hope this improves. Would be a very sad after spending $69K for the Hybrid and can only get to use 13 gallons per tank.
Old Dec 23, 2023 | 12:49 AM
  #161
ggebhardt's Avatar
ggebhardt
‘My 350h easily gets 35-38 mpg without trying hard. The colder weather will kill your milage on shorter trips. When my tank just reads half full, I can put in 9 gallons if I pump moderately slow.
‘’I am really enjoying my 350h, you should too.
Old Dec 23, 2023 | 06:06 AM
  #162
jahnjva's Avatar
jahnjva
Sorry to break it to you but you will only be able to put in 12-13 gallons after the warning light goes on and the pump clicks off. This should give you at lest 400 miles of range which is more than most ICE cars today. It's a Lexus glitch but still love my car.
Old Dec 24, 2023 | 06:08 AM
  #163
Seulbee77's Avatar
Seulbee77
6th Gear
Originally Posted by Tacoshawn
An update.
At 12 miles DTE it alerts on the center display that only 12 miles are remaining.
Before the alert the DTE counted down 1 mile for every mile traveled.
After the alert the DTE count down slowed dramatically which was unexpected. I didn’t reset a trip odometer because I didn’t expect the change in behavior. My estimate is it took another ~25 miles to get DTE to 0. Next time I’ll reset a trip odometer at the alert.
So, after much more driving that I planned I got DTE to 0.
After zero I continued driving and the DTE range of 0 was replaced by ‘Refuel’.
I then filled completely at Costco with 13.4 gallons. So, almost 4 gallons of tank capacity remaining @ zero range left. Extremely conservative.
I took it to the dealer and complained that I’m only getting 12 gallons in when I only have 10 miles left with gas guste blinking empty. I REALLY wanted 17 gallons in so I didn’t need to fill up so often. Dealer pumped it til gas pump stopped at 12.5 gallons. Then they kept pumping to show me you can put it additional gas, trying to get to 17 gallons, but it gas overflowed at 15.5 gallons. So 4 more gallons can go in after gas gauge clicks off. The dealer said there is couple gallons when it shows zero too.
I don’t think Lexus should advertise 17 gallons when you can’t fill it up 17 gallons with while showing almost empty sign. I was expecting 600+ miles between refuels. Had I known it could only take ~12 tanks, it would have been a dealbreaker for me…
Old Dec 24, 2023 | 06:51 AM
  #164
Seulbee77's Avatar
Seulbee77
6th Gear
An update.
Originally Posted by EMTLEX
Well here is an odd variation on the comments relating to Distance to empty... I put the gas nozzle on slow fill auto shutoff. DTE start mileage was 22. Filled the tank until nozzle tripped off and then squeezed another few squirts in totally 13 gallons. Distance to empty now reads 425. I then drove about 6 miles and let the vehicle sit for 90 minutes. I went to another gas station very close by and based on some comments here... I tried to see how much more I could add, still using slow fill speed. I could barely squeeze in one more gallon. BUT...THE DISTANCE TO EMPTY DID NOT INCREMENT PAST THE 425 DTE MARK!!! I would have expected it to increment something near another 27 miles. Didn't happen.
For those saying "deal with it" I would disagree. This is like saying if you bought the expensive sound system but couldn't get anything more than level 2 sound out of it... just deal with it. I think they are just waiting until the user satisfaction hits some kind of pain point. This is an engineering fail. This will cause people on longer trips to start looking for gas stations in remote areas when they don't need to. Thanks for listening....
Originally Posted by raytseng
I think people are jumping on you unnecessarily because there are 2 different issues combined in this thread that affect your range.
One is the fuel reserve and low fuel light being a bit high and where 0 is for the user display and range.
Two is the refuelling cutoff issue which is the main issue you are focused on.
I think you certainly can have issues of refilling is shutting off prematurely, and people maybe jump on and attack you for topping off because they aren't having the issue.
It's hard to quickly tell the difference unless you are doing some rough calculations.
I would say though that the float should be accurate. If it clicks off and you go in and the needle is above F, then it's full.
​​​​​5 gallons is a lot, if its 5gallons low, the needle should be well under F and an early cutoff. If you were able to fit 5more gallons in with the needle on F, something is terribly wrong like your fuel tank might have a defect or dent.
Given the active egr system this is a fussier tank than older or non hybrid cars, so I don't think you are crazy,.but also this is probably something wrong with just your car or your refueling technique and others don't have it.
The tips I can give for you to try to narrow it down if it is a refuelling technique issue is to try:
-a different station or pump to see if it's a specific pump that always causing you this behavior.
-not using the pump lever and manually pump a little slower than max speed, and with the nozzle firmly in and down, tilting nozzle tip up( in other words following how to use a gas pump by the book)
-Giving some extra time after pressing the fueldoor button before opening the lid and cap E.g. at least 30seconds after you pressed the button. Press button, work pump kiosk, then open tank.
This is a Lexus problem that needs to be addressed.
Mine showed empty with about 10 miles left. Lexus service center wanted to prove it could take 17 gallons but of course when the filled, it clicked off at 11.5 gallons. Car showed full tank with needle above F. Then Lexus service kept pumping and even when it kept clicking off until it overflowed at 15.5 gallons! I was able to drive 620 miles with that fill up.
Old Dec 24, 2023 | 09:00 PM
  #165
Seulbee77's Avatar
Seulbee77
6th Gear
Originally Posted by daryll40
Very impressive that any vehicle that weight can squeeze that many miles out of a gallon of gas
It may show that but you won’t get that much mileage if you just put in 12 gallons. That’s how mine showed, whether I put in 12 or 14 gallons from 10 miles left on DTE. I drive during no traffic times, same places and average 39-40mpg too. You won’t get actual 580 miles on the car at optimal conditions.
